Thread started 13 Jan 2010 (Wednesday) 12:08
540EZ
redfire2002
Jan 13, 2010 12:08 |  #1
will this flash work on my XSi? also, any thoughts about it?
Canon Gripped 5D II & 1D III ::: Canon EF 24-70L f/2.8 ::: Canon EF 70-200L f/2.8 ::: 580EX II & 580EX
hairy_moth
Jan 13, 2010 12:23 |  #2
This flash does not have ETTL and the High Speed Sync; so it will be more difficult to use on your camera than a newer flash. I have never used it, nor read the manual, so I am not sure how you will set your exposure (i.e., I hope you won't have to keep a table with ISO, f/stop, and distance).
The ETTL flashes are much easier to use -- basically just like your pop-up.
7D | 300D | G1X | Tokina 11-16mm f/2.8 | EF-S 17-55mm f/2.8 | EF-S 60mm f/2.8 Macro | EF 85mm f/1.8 | 70-200 f/2.8L MkII -- flickr (external link)
Shenanigans
Jan 13, 2010 12:48 |  #3
It will fire, but that is all it will do for you. You'll need to use a meter and set the flash power manually if you're going to use it as your primary flash.
MT ­ Stringer
Jan 13, 2010 12:49 |  #4
You can fire it from your camera but you will have to determine your exposure and do a little chimping to get your exposure right. It would be OK in a static environment but I wouldn't want to take it anywhere that might have different lighting.
I have had several and still have one. They work great for off camera strobist stuff. Manual only - no auto modes.
Example: Flash mounted on a balcony in a gym triggered remotely using the Skyports and powered by a Quantum Battery 1 battery.
IMAGE: http://i226.photobucket.com/albums/dd265/mt_stringer/Basketball/FlashSetup-650.jpg
MaxPreps Profile (external link)
My Gear List
Lyndön
Jan 14, 2010 09:27 |  #5
For Canon flash units, unless you want to only use the flash manually, I think you have to have an EX series.
1,348 views & 0 likes for this thread, 5 members have posted to it.
540EZ
1127 guests, 191 members online
