Thread started 13 Jan 2010 (Wednesday) 15:54
What was the most times you sent your equipment to Canon for the same/repeat problem?
garycoleman
Jan 13, 2010 15:54 |  #1
What was the most times you sent your stuff to Canon for same problem because it was still not working right after they fixed or they said it was in spec?
And, did they eventually fix it or give you a new one?
If you got a new one, how did you have to convince them or did they do it on their own?
My 7d is at Canon now for the 3rd freakin time to fix erratic AF issues. The 1st and 2nd time, I sent in only the body with a description of the problem. This time, being the 3rd time, I sent it in with a really detailed description, sample photos on CD, and my lens. I am pessimistic they will fix it this time because they weren't able to fix it the 1st and 2nd times. I think mine is just a lemon and it needs to be replaced but I don't know how many times I need to send it until they decide it is unrepairable and give me a new one.
Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
isaax
Jan 13, 2010 16:31 |  #2
Do you live in SoCal? If you do you can walk into their Irvine Service Center in person and show them what is going on.
7D | EF 70-200 f4L IS | Tamron 17-50 2.8 | EF 50 1.4 | Tokina 11-16 2.8 | AB800 | 430EXII | Vivitar 285 | RadioPopper JRX Studio (x3)
garycoleman
Jan 13, 2010 16:50 |  #3
isaax wrote in post #9387207 (external link)
unfortunately no. I live in SF so I'm no where close to it. I wish there was a service center up here though.
440roadrunner
Jan 13, 2010 16:56 |  #4
I have a pretty low tolerance for this sort of thing. I think THIS time I'd been on the phone DEMANDING to speak to a supervisor--and make it crystal clear how unhappy I was.
2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
Mamiya M645 1000S, 45mm 2.8, 80mm 1.9, 110mm 2.8 + 2x extender
pcunite
Jan 13, 2010 16:59 |  #5
garycoleman wrote in post #9386979 (external link)
Four...
Erik_L
Jan 13, 2010 17:06 |  #6
wow, and I thought VW was bad. "it's within spec"
Really!? I'm supposed to burn a quart of oil every 670 miles? You don't say!?
I sent my T1i to Adorama with a broken shutter and they sent me my money back. Saves me the hassle of selling the replacement :)
Canon EOS 1D III
Manfrotto 190X Pro B w/324RC2 "Action Head" | Canon 580EX II
Sigma 20 f/1.8 | Canon 35 f/1.4 L | Sigma 50 f/1.4 | Sigma 85 f/1.4 | Canon 135 f/2 L
Flick (external link)r
JC4
Jan 13, 2010 17:11 as a reply to  @ Erik_L's post |  #7
50 f/1.2, 4 times, and Canon finally acknowledged the problem and replaced it.
It wouldn't focus with outer AF points(mostly left ones). Freaky problem, but no excuse for sending it back "adjusted and in spec" 3 times. Another member with a similar issue suggested filing a report with the BBB. It seemed to help, getting me in touch with someone higher up at Canon.
John Caputo
JeffreyG
Gallery: 42 photos
Jan 13, 2010 17:19 |  #8
Two. Once lens only - still off and then again with a body. After the second time it was corrected.
Erik_L
Jan 13, 2010 17:22 |  #9
Looks like this is why Canon has enabled micro adjust - to save them the headache!
Canon EOS 1D III
garycoleman
Jan 13, 2010 17:42 |  #10
440roadrunner wrote in post #9387345 (external link)
the CSR who helped me arranged to send it in the 3rd time, told me to call and speak to his supervisor when it arrives at the service center so he can get a senior tech to look at it. Tracking shows they recieved it yesterday, I called today, my camera is not in their system yet. They told me to try again tomorrow. vmad
garycoleman
Jan 13, 2010 17:44 |  #11
JC4 wrote in post #9387452 (external link)
I have a terrible feeling it will come to this. How easy was it to get Canon to send you a new one after reporting them to the BBB?
garycoleman
Jan 13, 2010 17:47 |  #12
Erik_L wrote in post #9387540 (external link)
i wish it was that easy. It's not a constant front or rear focus. It is just inconsistent. Sometimes spot on, and other times terribly OOF. I confirmed this using controlled tests on a tripod and an easy to focus target.
JC4
Jan 13, 2010 17:50 |  #13
garycoleman wrote in post #9387699 (external link)
Easy, once they received a copy of the report, contacted me, and had me ship the lens in one last time(the 4th). But, its a slow process. If you have a reproducible problem, and documented lack of service, you might as well file a report and see if you can get some action, while pursuing other suggestions above.
John Caputo
garycoleman
Jan 14, 2010 11:13 |  #14
JC4 wrote in post #9387735 (external link)
thanks for the tips. i will purse this option if it comes back unresolved.
1,856 views & 0 likes for this thread, 7 members have posted to it.
1448 guests, 149 members online
