Thread started 14 Jan 2010 (Thursday) 22:55
Noobie question on shooting window scenes
coldcanuck
Jan 14, 2010 22:55 |  #1
My wife is in the window treatments business and wants to develop a portfolio of her company's work for the sales ladies, but our trusty point-and-shoot camera was not up to the task. So after reading a number reviews and reading recommendations in forums on cameras, so I recently picked up a Rebel XSi with the stock 18-55mm EF-S lens. I don't have an external flash.
The problem is that the inside of the homes where we take pictures is often dark, but when you take a picture of the window you have the problem of the bright light coming in thru the window, a problem compounded in winter because of the immense amounts of snow covering the ground and trees. This results in the camera metering off the window light.
How do I mitigate this problem? Would a 430EX II or a 580EX II flash help my problem?
coldcanuck
jimmeh
Jan 15, 2010 03:32 |  #2
expose for the inside (ie meter off a wall that is typical of the light in that room).
Experiment with the angle as well...straight on if the window is clean you'll probably have trouble seeing it too well anyway.
Marius ­ B
Jan 15, 2010 03:47 |  #3
Use a CPL, it will remove any reflections in the window.
Edit: Sorry, misunderstood the question :)
www.bottolfsen.com (external link)
Flickr (external link)®
Facebook (external link)
5D MKII, 5D, EF 17-40, EF 24-70, EF 70-200 f2,8 IS, EF 35 f1.4, EF 100 f2.8 IS
DStanic
Jan 15, 2010 06:51 |  #4
I think a flash (such as the 430exII) would help the problem by bouncing the flash off the ceiling or a wall. Hitting it directly can't be doing any good.
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
neilwood32
Jan 15, 2010 07:04 |  #5
You can approach this in a few ways:
1) Expose for the inside with existing light - your problem here is that exposing for the interior will probably mean that the window itself will be too bright and you will blow the highlights.
2) Use a flash - This will help balance the light between interior and exterior however you will have to be careful with the shadows. Bouncing might help as it effectively increases the size of the light source.
3) Additional interior lights - even adding a standard lamp or 2 will help increase the interior light (and might make it easier to arrage the positioning to make control of the shadows easier).
4) Do your product shots in a controlled enviroment - set up a small area as a studio with constant lighting and a sample window. This will enable the products to be shot consistently.
The problem with shooting in situ is getting all your product shots to be consistent (white balance issues, exposure, shadows etc) whereas studio means full control.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jan 15, 2010 09:12 |  #6
Or, you could wait until the exterior light level matches the interior level.
And, take the time to learn how to shoot on "M". Why? Post #47
Click the post #47 at the top-right of that post if you'd like more info on the subject.
tzalman
Fatal attraction.
Jan 15, 2010 09:17 |  #7
One more possibility to add to the list above:
Create what is called an HDR, High Dynamic Range, photo. Essentially two shots with a tripod mounted camera, one for the outside view through the window and the other exposed for the interior. These are then blended together in the appropriate software.
Elie / אלי
krb
Jan 15, 2010 09:19 |  #8
neilwood32 wrote in post #9397760 (external link)
A fifth option would be to hang neutral density gel over the outside of the window to reduce the light coming through from outside.
You could also consider HDR or exposure blending. Basically, using post-processing techniques to balance the exposures.
-- Ken
Gear list
jimmeh
Jan 15, 2010 10:45 |  #9
are you trying to get a photo of the glass itself, considering you're wanting to show the results of window treatments?
krb
Jan 15, 2010 11:50 |  #10
jimmeh wrote in post #9398833 (external link)
window treatments == curtains, blinds, etc. around the the window
-- Ken
Gear list
coldcanuck
Jan 15, 2010 13:18 |  #11
Thanks. I think maybe what I'll do is rent an 580EX II flash for the day (relatively cheap at $12 a day) and then go take some pictures towards the end of day when the outdoor lighting is reduced. I would prefer to go in at night and take the photos, but these are model homes and I don't think the sales lady wants to stay after hours while I take photos.
Thanks all for the feedback.
coldcanuck
757 views & 0 likes for this thread, 8 members have posted to it.
2623 guests, 154 members online
