Thread started 15 Jan 2010 (Friday) 11:48
file size difference between cs3 and DPP
brit84
Jan 15, 2010 11:48 |  #1
Hello,
I would like to know why there is a big difference between the jpeg conersion file size of DPP and CS3. My 10mp files are generally in the 5-7 MB when converted from raw to jpeg with DPP, but are around 2-4MB when I use CS3. Both have output at 300dpi and maximum quality
Am I losing quality with cs3 or is it simply beign more efficient? Am i doing somthing wrong?
5DIII/grip |5DII/grip | 40D/grip | 17-40L| 24-70L 2.8 II|70-200L IS f2.8 II | 580EXII x2 | Lensbaby composer | Benro 358 w/ Q3 | 2 Einsteins/Vagabond mini.
Facebook (external link)
Website (external link)
egordon99
Jan 15, 2010 13:01 |  #2
First off, DPI is utterly meaningless in this context. What compression level are you using in both programs? Assuming you're not resizing (changing the pixel dimensions), the compression level could have a big impact on the file size.
sapearl
Gallery: 63 photos
Jan 15, 2010 13:08 |  #3
It's been quite a while since I've used DPP but CSX allows quality levels from 1-12 (I didn't count "0"). Typically on my 5D I'll use level "10" for the files I send to the level which is about 90% quality level. It sounds like you are trying to make an apples to oranges comparison. As Gordon indicates, compression level is the key here ;).
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
siriusdogstar
Jan 15, 2010 13:22 |  #4
another file size difference is caused by inclusion (or not) of ICC profile, and of EXIF information.
sapearl
Gallery: 63 photos
Jan 15, 2010 13:36 |  #5
I can't talk intelligently of ICC, but I thought EXIF by default was contained in the RAW file?
siriusdogstar wrote in post #9399776 (external link)
egordon99
Jan 15, 2010 13:45 |  #6
sapearl wrote in post #9399856 (external link)
Correct, but if you strip it out when saving to JPG, you can save some file space(but not ~2-3MBs worth)
sapearl
Gallery: 63 photos
Jan 15, 2010 13:48 |  #7
Ah! Totally forgot about that :rolleyes:. Thanks for clearing that up Evan. It's something I don't do so I never even thought of it.....
egordon99 wrote in post #9399918 (external link)
Panopeeper
Jan 15, 2010 16:35 |  #8
This is a difficult subject. When converting an image in JPEG, there are usually 256 parameters and an important decision, which influance the size and quality of the output. The "quality" settings (a number from 1 to 10 with DPP, or 1 to 12 with Photoshop, or a percentage, or whatever) are totally arbitrary and not comparable between programs; they are only for the user interface.
Increasing the "quality" means increasing the file size compared to a lower "quality" setting of the same program. However, an image with higher file size created with one program is not necessarily better, than a smaller one created by another program. Even worse: the resulting quality depends on the image content as well; not all images require the same JPEG encoding level.
Perhaps the best is to create JPEGs from images with very fine details, straight lines, plain unicolored, untextured patches with different "quality" settings. Then open the JPEG images in Photoshop or whatever and look at the critical parts in 300%. (Note: saving and reopening the images is absulutely required, otherwise you see the original content without the JPEG degradation.)
Gabor
tim
Light Bringer
Jan 15, 2010 16:43 |  #9
I could explain it, but it'd take too long. Don't worry about it as long as the images look good.
880 views & 0 likes for this thread
Latest registered member is Wuu
1017 guests, 351 members online
