Thread started 16 Jan 2010 (Saturday) 08:03
Canon 7D wireless flash problem -- cannot disable popup
DrPablo
Jan 16, 2010 08:03 |  #1
Just got my new 7D and I'm trying to figure out wireless flash with an off-shoe 580EX.
I know how to select the option that uses the external flash only, i.e. not the popup, but when that's selected the popup flash still fires (and quite brightly at that).
I haven't upgraded the firmware yet -- is this a known problem that the firmware has handled?
Canon 5D Mark IV, 24-105L II, 17 TS-E f/4L, MPE 65, Sigma 50 f/1.4, Sigma 85 f/1.4, 100 f/2.8L, 135 f/2L, 70-200 f/4L, 400 L
Film gear: Agfa 8x10, Cambo 4x5, Noblex 150, Hasselblad 500 C/M
dmstraton
Joined Jun 2005
Jan 16, 2010 08:10 |  #2
It will fire a preflash to tell the other flash what to do, determine exposure, etc.
If it is still flashing to expose, you might have incorrectly chosen to fire both - check again and ensure that you have only selected the external flash icon, not the ext flash + internal option.
dmstraton
5DmkII, Zeiss 21 f2.8, Zeiss 35 f2, Zeiss 50 f2 Makro-Planar, 580EXII, Voigtlander Bessa R2M, Voigtlander 35 f1.4 Nokton
DrPablo
Jan 16, 2010 08:22 as a reply to  @ dmstraton's post |  #3
Thanks, but I'm quite sure I've selected the right one. There are three options and only one of them is external flash alone.
The flash is bright enough to cast a visible shadow off the lens in the photo.
PacAce
Joined Feb 2003
Jan 16, 2010 09:09 |  #4
DrPablo wrote in post #9404369 (external link)
How close are you to the subject or whatever the shadow is cast upon?
...Leo
DrPablo
Jan 16, 2010 09:18 as a reply to  @ PacAce's post |  #5
Well, I was just testing it out so I was only a couple feet away from it, I haven't tried with a worthwhile subject.
PacAce
Joined Feb 2003
Jan 16, 2010 09:39 |  #6
DrPablo wrote in post #9404607 (external link)
What you're seeing is normal. Even though you have the built-in flash set not to fire, it still will but at a very low power level. Ordinarily, you won't see the effect of the built-in flash firing but if the lighting is low and the off-camera flash does not light up the entire scene or if the ISO is set relatively high, you will see the effect of the built-in flash as you did.
...Leo
CxThree
Jan 16, 2010 10:48 |  #7
http://www.usa.canon.c​om …ctID=329&articl​eTypeID=48 (external link)
For more info, see the videos at that link.
You are seeing normal wireless flash behavior. It's the same way on a Nikon system. The on camera flash will fire a small flash that will not be involved in the exposure.
Canon EOS 5D MKIII, 7D
Canon Lenses : 70-200 F2.8L II IS : 24-105 F4L IS : 16-35 F2.8L : 50mm F1.4 : 85mm F1.8 : 100mm F2.8 Macro : 10-22mm
4x 600EX-RT
Speedotron Black Line
int2str
Jan 16, 2010 11:41 as a reply to  @ CxThree's post |  #8
Please see the 7D ETTL FAQ here (Items 4 & 5) that explains the phenomenon:
https://photography-on-the.net/forum/showthre​ad.php?t=767760
And here's a workaround for the light spill:
https://photography-on-the.net/forum/showthre​ad.php?t=785999
linh811
Jan 17, 2010 22:30 |  #9
int2str wrote in post #9405255 (external link)
THANK YOU !!!!! I ONLY shoot with OCF, was wondering how to defeat that damn popup!!!
7D || 5D2 || three 580exII's | 430exII | 24L II | 50L | 100L macro | 70-200/2.8L IS | 24-105L | canon 50/1.4 | canon 17-55/2.8 | Sigma 35/1.4 |Sigma 50/1.4 | Tamron 24-70/2.8 VC |Pocket Wizard Plus II. slingpro 100 and 200, and a million other accessories I can't even remember.
loco69
May 12, 2010 04:55 |  #10
Trap for young players!
Problem fixed - but I could see one button on one side and thought that perhaps there was a depressed button on the other side (mucked about with that for ages)... Alas there wasn't - must just be a small hole! One button on one side only. Thanks to all of you for your fine solution/s.
Tony.
apersson850
Gallery: 11 photos
May 12, 2010 06:49 as a reply to  @ loco69's post |  #11
Which button are you referring to?? ???
Anders
5,076 views & 0 likes for this thread
Latest registered member is Omgitsbeks
1126 guests, 152 members online
