Thread started 16 Jan 2010 (Saturday) 16:46
Drop Shadows
shane_c
Jan 16, 2010 16:46 |  #1
I currently have 2 layers (background, gradient). There is a square object in the background layer that I want to add a drop shadow to.
I've tried creating another layer (background copy) and then using the rectangle selection tool to outline it and go to blending options but that does nothing.
How do I go about adding the drop shadow to just the square box?
Canon R5 - Canon RF24-105L F4, Canon 40mm, Canon 70-200L F4 (non-IS), Canon 100-400ii, 1.4xiii
G1X MK2, G15
My Instagram (external link)
HankScorpio
Jan 16, 2010 16:59 |  #2
So, you have this on a background (but less ugly I hope)
And you want this?
If so, then:
1. Create a new blank layer above the background.
2. Select your rectangular shape and fill it with black on the new layer.
3. Create your drop shadow with blending options as usual.
4. Now set the new layer's blend mode to screen and the horrible black fill you created will vanish, leaving only the drop shadow.
If you're after something else then let me/us know.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
basroil
Jan 16, 2010 18:03 |  #3
shane_c wrote in post #9406711 (external link)
1) don't have the square object be in the background, place it in it's own layer (just that object) and just use blend
2) this will not be good for say, a table leaving a shadow on the floor. for that, outline the object, then ctrl+t, then skew, stretch, rotate, and otherwise modify the object until it is where you want the shadow to be. then blend options, solid color (black, brown, or blue depending on the WB difference of other shadows in the picture). Then blur it a bit until you get exactly what you want
shane_c
Jan 16, 2010 20:22 |  #4
Thanks!
G1X MK2, G15
ssim
Joined Apr 2003
Jan 17, 2010 00:58 as a reply to  @ shane_c's post |  #5
I would normally use a layer style for a simple drop shadow. The nice thing about this is that if you are planning on using the same settings on other objects/layers/files you can save this to your styles panel. On any subsequent uses you simply click once on the saved item in your style panel and it applies all settings in one click.
IMAGE: http://www.pbase.com/ssim/image/121148897.jpg
This is the above settings
IMAGE: http://www.pbase.com/ssim/image/121148898/medium.jpg
If you want the shadow or other effects to move to a different direction in differnt layers of the same file you have to uncheck "Use Global Light". This item assumes that the light that is creating your shadow will always be coming from the same direction in the file.
1,028 views & 0 likes for this thread, 4 members have posted to it.
Drop Shadows
1368 guests, 194 members online
