I am looking to use a pocket wizard or a cyber sync connected to my cameras sync port, and use a flash on its hot shoe. Any one know of a goo way to get the transmitter mounted to the camera easily?
Thanks!
joey1234 Senior Member 538 posts Joined Dec 2007 Location: Long Island, NY More info | Jan 17, 2010 09:31 | #1 I am looking to use a pocket wizard or a cyber sync connected to my cameras sync port, and use a flash on its hot shoe. Any one know of a goo way to get the transmitter mounted to the camera easily?
111t Senior Member 577 posts Joined Apr 2009 More info | Jan 17, 2010 10:51 | #2 I generally use a stroboframe flip bracket. If I'm using the 580II on the bracket, the transmitter has to plug into the side of the camera. I used some velcro to stick the transmitter to the vertical arm of the bracket. If i'm using the 285... i plug the vivitar into a wein safe sync plugged into the hotshoe. The transmitter can then slide on top of the safe sync. The only problem is that i have to use the calumet 4 channel transmitter because the cybersync is too tall for the swing arm to clear it. That sucks because the cybersync is a much better radio trigger... All The best!
pablo9 Member 91 posts Joined Aug 2007 More info | Jan 19, 2010 13:56 | #3 Custom Brackets folding T bracket.
canondslr Senior Member 944 posts Joined Aug 2006 Location: USA More info | Feb 20, 2010 04:18 | #4 Hi 111t, can I ask you something about vivitar flash + wein safe sync ?
111t Senior Member 577 posts Joined Apr 2009 More info | Feb 20, 2010 07:35 | #5 canondslr wrote in post #9644845 Hi 111t, can I ask you something about vivitar flash + wein safe sync ? I was trying to use vivitar 283 on my 5D, so I used the wein safe sync in between, but it would not trigger it. is there anything that i did wrong ? the set up is just very direct, camera + wein + vivitar 283, thats it. TIA I've gotten mixed results using the actual hotshoe on the safesyncs. I found that my cst would not work on that hotshoe unless i pressed it firmly down while it fired. (Which is completely impractical for normal use) Any flash with a rotating locking collar seems to work ok. The vivitars have that locking lever thing so i don't know... I mainly use the safesync to connect my 285 to the hotsoe on the camera with a cord. The actual flash is mounted on a bracket arm. Have you tried that? I use either a vivitar or paramount coiled pc to vivitar cord to connect the safe sync to the flash. IMO those are some of the better cords... but they wear out eventually. I always have a spare new one around. Good news is they're not very expensive. All The best!
zelseman Goldmember 1,922 posts Likes: 34 Joined Mar 2008 Location: Tahlequah, OK More info | Feb 20, 2010 16:12 | #6 |
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Feb 20, 2010 23:02 | #7 joey1234 wrote in post #9410525 I am looking to use a pocket wizard or a cyber sync connected to my cameras sync port, and use a flash on its hot shoe. Any one know of a goo way to get the transmitter mounted to the camera easily? Thanks! I guess Tracy doesn't want to reply to the advice posted.
| Latest registered member is Mihai Bucur 1165 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
