Thread started 19 Jan 2010 (Tuesday) 02:11
Flash Bracket to hold a Canon 5D MKII and 580 EXII
tonyniev
Jan 19, 2010 02:11 |  #1
I am looking at a flash bracket and want to know brand and model that would hold my camera Canon 5D mark II and flash speedlite 580EXII.
I read in the B&H reviews that the DOT extended Stealth models for EOS may not hold the 580EX...anyone has experience with th ebigger DOT RPS Digital that also has the shutter cable from the bracket?
Any other brands or models I should consider?
Cheers,
Tony
Leica M10 & M3
Sony A7R4 & A7R
Canon 5D2 & 7D
jeromego
Jan 19, 2010 08:13 |  #2
Custom Brackets Pro M.
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
Patrick
Jan 19, 2010 08:20 |  #3
jeromego wrote in post #9424728 (external link)
Yep. It's pricey but is built very solid. It also rotates the correct direction so when you're using a grip you're not holding the camera in an awkward position.
Bodies, Lenses, Lights, Stands, Transmitters, Receivers, Tripods, Meters, etc...
Familiaphoto
Jan 19, 2010 09:07 |  #4
I use the Really Right Stuff B87-B. A bit expensive and does require an L-Bracket but it is truly outstanding in construction, weight and ease of use.
http://reallyrightstuf​f.com …tems.asp?kc=B87​-B-PPP&eq= (external link)
Paul
Blog (external link) | Gear (external link) | Gallery (external link)
Bag Reviews: Domke F-3x | More to come...
sapearl
Gallery: 243 photos
Jan 19, 2010 09:28 |  #5
Check out Newton - built like a tank, light weight, solid, expensive, compact, durable, performs as advertised:
https://photography-on-the.net/forum/showthre​ad.php?t=338933
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
tonyniev
Jan 19, 2010 09:35 |  #6
thanks for these suggestions, I have to try out t the local photo store, this is one gadget that needs to be purchased locally not thru the internet.
Cheers,
Tony
Leica M10 & M3
Sony A7R4 & A7R
Canon 5D2 & 7D
sapearl
Gallery: 243 photos
Jan 19, 2010 09:56 |  #7
I would tend to agree Tony - brackets are highly personal items, often fitting comfortably like gloves...... or not.
My first bracket when I shot medium format film was actually an old Stroboframe I retooled with parts from a Metz, some nuts and bolts, and a nylon strap from a baby carrier. It took a while to arrive at that solution, but when it was done it was balanced, very comfortable and put the flash exactly where I needed it :D.
tonyniev wrote in post #9425147 (external link)
pablo9
Jan 19, 2010 10:40 |  #8
If you're looking for something compact and easy to carry, take a look at Custom Brackets folding T. (external link)
Dermit
Joined Nov 2005
Jan 19, 2010 13:15 |  #9
+1.... what I use and love it.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
tonyniev
Jan 19, 2010 13:18 |  #10
thanks Pablo
Cheers,
Tony
Leica M10 & M3
Sony A7R4 & A7R
Canon 5D2 & 7D
John ­ E
Jan 19, 2010 13:20 |  #11
+2. What an awesome bracket. Sometimes you can get a good deal on Ebay.
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
sapearl
Gallery: 243 photos
Jan 19, 2010 13:36 |  #12
Even though I own a Newton I will say that Custom brackets are very well made. The just offer a different size and configuration than the Newton line.
OldA1
Jan 19, 2010 15:55 |  #13
+3 - expensive but I would do it again. Custom Brackets also now makes camera plates that allow for the Manfrotto style quick release as well as arca swiss style L-brackets and plates. These allow you to keep your preferred quick release attached to camera when using the flash bracket.
Peace
Mark
Wilt
Jan 19, 2010 19:32 |  #14
Newton, Custom, and RRS are all pro grade products much loved by working pros. These are listed in order of increasing purchase price; all are $200 or higher. Newton and RRS are both light weight and sturdy. Custom tends to be heavier. Note that Custom has two versions of the same fundamental design, and one version forces clockwise rotation of camera to Portrait orientation, which is suboptimal for anyone who likes the supplemental control buttons found on the Canon battery grip.
Brackets less than $200 generally have some deficiency in design which makes them suboptimal.
[edit] One forum member 'called' me about the rotation, and I checked and he was right. Both versions of a single design are right handle vs. left handle, but use the same camera rotation (CCW) in both cases!
drdiesel1
Gallery: 86 photos
Jan 19, 2010 19:42 as a reply to  @ OldA1's post |  #15
I used this 6 dollar heavy duty hand made unit with great results ;)
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
10,891 views & 0 likes for this thread, 20 members have posted to it.
1634 guests, 136 members online
