Im am a novice with CS4.
My question is, can I add to an existing action?
I was given a nice framing action.
I want to add "save as and close" to this action.
Any tips.
Thanks in advance.
carshop Goldmember 1,846 posts Joined Jun 2009 Location: Ontario, Canada More info | Jan 19, 2010 09:54 | #1 Im am a novice with CS4. ShawnSmugmug
pturton Senior Member 733 posts Joined May 2002 Location: Region Niagara, Ontario, Canada More info | Jan 19, 2010 11:17 | #2 The help in Adobe Photoshop is an amazing thing BUT you need to know what to search for.
Jan 19, 2010 12:02 | #3 Thanks ShawnSmugmug
dugcross Senior Member 879 posts Likes: 3 Joined Jan 2008 Location: St. Petersburg, Florida More info | Yes you can. With the action panel open. Click on the triangle next to the action you want to change. Once that is open, select the name of the action. While that is selected go to the panel options in the top right corner of the panel. Pull down to "Insert Menu Item...", when that window opens up, go to file and select "save" under "file" menu then hit ok on this window. You should see that it added a save step into that action. Then go back to the panel options and select "Insert Menu Item" again, once the window is open, select "close" under "file" menu then hit ok on window. That will put a close step under your save step that you just made. They should automatically go to the bottom of that particular action but if it does not you can just drag and drop it to where you want it. Doug Cross
dugcross Senior Member 879 posts Likes: 3 Joined Jan 2008 Location: St. Petersburg, Florida More info | Also I just realized. If you're ending up with a layered file and you're saving it to a file type that cannot have layers you will need to add a flatten command before the save step otherwise you will have to hit the save button before it will close. Doug Cross
Jan 19, 2010 14:48 | #6 Thanks ShawnSmugmug
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jan 19, 2010 16:02 | #7 I would not add the save and close to the action. "I think the idea of art kills creativity" - Douglas Adams
Jan 19, 2010 19:45 | #8 René Damkot wrote in post #9427674 I would not add the save and close to the action. Use the image processor (Bridge > Tools > PS > Image Processor) instead. Way more flexible and less prone to errors. Better yet, useDr. Browns 1-2-3-process Thanks, will give it a go. ShawnSmugmug
| Latest registered member is zachary24 1437 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
