FORUMS Photo Sharing & Visual Enjoyment Transportation
Thread started 20 Jan 2010 (Wednesday) 01:07
AUSSIE C130's
macca172
Joined Sep 2009
Jan 20, 2010 01:07 |  #1
Aussie Air Force C130J and a C130H doing laps around my place this afternoon.
Canon 5D MkII, 50D and 400D with Grip: Canon 70-200 2.8L: Sigma 120-400: Tamron 18-200and a few others!
RadAL
Jan 20, 2010 01:14 |  #2
*before all the slow your shutter speed comments*
Omfg, I hope they got all the Engines going again, did they crash? lol
macca172
Joined Sep 2009
Jan 20, 2010 01:21 |  #3
The Aussie's have been operating C130's since 1958. They were the first country outside the USA to have them...A,E,H and J models! They have never lost one yet.
pixelbasher
Jan 20, 2010 01:28 as a reply to  @ macca172's post |  #4
I think he's taking the piss macca ;)
Radal, really,how much prop blur do you want? Surely the first one has enough?
50D. 7D. 24-105L. 100-400L. 135L. 50 1.8 Sigma 8-16
flickr
FlyingPhotog
Cream of the "Prop"
Jan 20, 2010 01:33 |  #5
Exposures look pretty good but I'm guessing there's some pretty significant cropping being done here maybe? 50% ?
For the shutter speed used to get this result (again guessing but I'd wager around 1/500 or maybe even 1/750) I'd expect the overall image to be sharper.
I'd call the amount of blur on the low end of acceptable. It's not the be all and end all but if your going to come even close to freezing the props, at least get the airframes sharp.
Jay
Desertraptor
Gallery: 212 photos
Jan 20, 2010 01:34 |  #6
I take my Herc shots at 1/200th front on but side on like these this speed isn't too bad
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
RadAL
Jan 20, 2010 01:41 |  #7
yes, I was kind of joking...
macca172
Joined Sep 2009
Jan 20, 2010 02:11 |  #8
Radal, Its ok mate I took it as a joke, no probs at all, my reply was purely for educational purposes only.
FlyingPhotog, Great advice and yes crop was roughly 50%. They(both aircraft) were approx 3/4 mile abeam my place and hence the aircraft took up roughly only 15% of the whole frame.
The J Model was taken at TV400, F13, ISO400 and EV +1/3. The H model was taken at TV640, F11 ISO400 and again EV+1/3. Sigma 120-400mm lens.
RadAL
Jan 20, 2010 02:29 |  #9
thanks, hope you show more in the future.
PhotosGuy
Joined Feb 2004
Jan 20, 2010 09:07 |  #10
These are acceptable 'grab shots' shooting from a less than ideal distance, but we always try to push the limits, don't we? That's how we get better at anything, so...
"Want" vs. need vs. reality... tough question! First, a given speed of 1/200 sec will give a different amount of apparent blur depending on the angle you are to the AC, if all other things are equal (RPMs, etc.) In profile shots you get the least amount of apparent blur, so you have to at least try a bit harder which it doesn't look like you took the time to do.
Why do I say that? If you had shot at even 1/200, I'd think, "The guy gave it a try, & that's the best you can do." And because...
This says to me that you had a lot of time to set your exposure. But here's the EXIF from #1:
# Exposure Time (1 / Shutter Speed) = 1/400 second ===> 0.0025 second
# Lens F-Number / F-Stop = 13/1 ===> ƒ/13
# Exposure Program = shutter priority (4)
# ISO Speed Ratings = 400
# Focal Length = 400/1 mm ===> 400 mm
1/400 second is logical shooting a 400mm focal length, so I won't pick on that, this time.
f/13 is not. There's no need for that much DOF. See the DOF calculator at the bottom.
Depth of field and aperture selection question.
ISO 400 isn't necessary either. You had sunlight, & by lowering the f-stop, you could have used ISO 100.
Now look at the EXIF from the second shot:
# Exposure Time (1 / Shutter Speed) = 1/640 second ===> 0.00156 second
# Lens F-Number / F-Stop = 11/1 ===> ƒ/11
1/640 sec? Did the engine RPMs change that much? You changed the aperture to f/11 knowing(?) that that would increase the shutter speed, so it looks to me as if you were just pulling numbers out of your hat without considering the consequences. ;)
I don't always succeed either, but at least I do try to get an acceptable blur, knowing that it's probably not going to be anywhere near what the AC pros will get in the same shot. There's a lot of black magic involved in shooting prop jobs & one set of settings won't always work for the same aircraft even 30 seconds later. Experience makes a difference. An example would be in the pattern vs. landing with the throttles back, or climbing vs. diving. Experience makes a difference as well as reading other peoples experiences.
See the links in: Shooting airshows in Manual
SMBPhotography
Jan 20, 2010 10:59 as a reply to  @ PhotosGuy's post |  #11
Those bring back alot of memories from living on a base where they were stationed.
Steve
Gripped 30D, Gripped 7D, G9, 24-70L F2.8, 100-400L F4.5-5.6, 50mm 1.8, 18-135mm 3.5-4.6, 430EXII and a whole bunch of other stuff.
I'm no Jay Beckman but I did sleep at a Holiday Inn last night.
snails
"I used the last of it to tip the strippers."
Jan 20, 2010 11:44 |  #12
That 43-year old design is still pretty.
pixelbasher
Jan 21, 2010 05:17 as a reply to  @ snails's post |  #13
Hey photosguy, your quoting of two comments suggests the same person asked them. I didn't take the shots, I was merely the one questioning just how much blur is enough to stop the comments about frozen props!
As far as I'm concerned, and my point was, as long as they aint frozen solid, then surely that's enough? Sure, a perfect circle seems to be the ultimate challenge, but how many of us "norms" can consistanly shoot moving aircraft at 100th or less? I agree of course though, it is always better to push yourself to improve, that goes in any aspect of life. But if you don't see them that often, why risk getting nothing useable at 100th when you can grab a keeper at 400th, albeit with only a smidge of prop blur of course.
And not to sound rude to macca, but imho the prop blur isn't really the top C&C issue in these shots, I'd say it's more the big crop combined with 400 ISO
I was watching some hornets two days ago doing simulated bombing/strafing runs a couple of KM from the road, but I didn't even pull the camera out as they would have been just a little dot in the picture I would have had to crop the heck out of. Maybe I should have..... At least nobody would have niggled me about the prop blur on them! :lol:
Still, I do love hercs, so thanks for posting them Macca.
flickr
macca172
Joined Sep 2009
Jan 21, 2010 09:00 |  #14
To blur or not to blur..surely that is the individuals choice?
pixelbasher
Jan 21, 2010 09:26 as a reply to  @ macca172's post |  #15
definately, but to be totally honest, more does look better than less.
IMHO the amount on your first one at 400th looks fine to me, you can see they are turning, so it doesn't look like it's going to fall out of the sky. The second one doesn't have as much, but once again, you know they are turning in the pic.
This is one reason I like taking RC model plane shots, I can shoot at 1/1000 and still blur the props into non existance :lol:
flickr
2,857 views & 0 likes for this thread
AUSSIE C130's
Latest registered member is zev
884 guests, 329 members online
