I have just bought and used the sensor swabs for my D30 http://www.photosol.com/swabproduct.htm![]()
With a bit trepidation i did 2 cleans and things seem alot better.However it does seem a bit of a waste throwing the spatula bits away after just using them the once.
Is it possible to re - wrap the spatulas with some proper unused sensor cleaning material and using the spatulas again.
If so what cloth/material can you use and is there a knack to attaching and fitting the correct size to the spatular.Many thanks.
