Thread started 20 Jan 2010 (Wednesday) 03:24
whats this dial for?
jc450d
Jan 20, 2010 03:24 |  #1
hi have a 17-85 lens.It has a dial reading from macro to infinity.Is this to control the depth of field?If so would setting to a low number produce a storytelling image and infinity a singular image?thanks in advance
TweakMDS
Jan 20, 2010 03:26 |  #2
Is it the focus limiter switch? I don't know if the 17-85 has one, but they are normally used to limit a lens' focus range, so the intended focus is over a smaller area and thus - faster.
Or are you talking about the focus ring? :D
Some of my lenses focus beyond infinity...!
~Michael
Gear | Flickr (external link)
"My featured shots" (external link)
xarqi
Jan 20, 2010 03:28 |  #3
jc450d wrote in post #9431583 (external link)
Focus ring?
P.S.
Yes - I found an image of the 17-85. What you are looking at is the distance scale that shows how far away the lens is focussed. It will change as the lens changes focus, either automatically or when you use the focus ring manually.
Depth of field is primarily controlled by aperture (wider aperture -> shallower DoF and vice versa), but there are other factors.
gasrocks
Jan 20, 2010 06:50 |  #4
Did your lens come with the instruction sheet? If so you might want to read it. Lots of good info there.
egordon99
Jan 20, 2010 07:06 as a reply to  @ gasrocks's post |  #5
No focus limiter on the 17-85, it doesn't need one as the AF is really fast. You are looking at the distance scale. It shows what distance the lens if focused at.
893 views & 0 likes for this thread, 5 members have posted to it.
1009 guests, 184 members online
