Thread started 20 Jan 2010 (Wednesday) 13:08
Permanent or portable
SteveInNZ
Jan 20, 2010 13:08 |  #1
I asked a question about light pollution as a limiting factor which lead to the issue of the pros and cons of a permanent versus portable setup.
Mint Mark made the following comment when Adrena1in said he was building a pier and chris said he was thinking about it too.
I got a portable set up (astrotrac) because I don't usually have much observing time so I wanted to be able to get out into the garden and going quite quickly. The set up does achieve that, but it has performance limits... like I'm finding out how it is entirely dependent on good alignment.
So then I think of the next step which is a larger mount that can do auto guiding... and I imagine having to drag that in and out and set it all up. Not practical for me.
So then I think of the step after that which is the permanent observatory... adapted shed, fence panels, whatever. Apart from being a pretty major DIY project, I always wonder if it's worth the effort in my location...
Pros...
* Quick startup as mount is pre-aligned.
* Better mount and auto guiding supports bigger aperture, longer focal length and exposure time.
* Longer imaging sessions as you could leave it going and go to sleep.
Cons...
* Big DIY project... the concreting part scares me
* Security might be a concern? Perhaps still some carrying back and forth to get going.
* Still limited by the light pollution at your location (back on topic!)
I thought it was worthy of its own discussion.
Steve.
"Treat every photon with respect" - David Malin.
chris.bailey
Joined Jul 2003
Jan 20, 2010 13:49 |  #2
Darn it, just posted a reply under the old thread!
SteveInNZ
Jan 20, 2010 15:13 as a reply to  @ chris.bailey's post |  #3
Something like pier doesn't make sense for me at the moment as I have an SCT on a fork mount with ye olde setting circles. I'd be better putting those funds towards an HEEQ5 or EQ6. Since we don't have a polaris, a smart mount is going to make quite a difference to setup times.
I'm thinking that I can make a vast improvement on my current situation at home by buying some welders screens to block the light from the local gas station and the neighbours sensor lights. Add to that a secure, weatherproof box near my setup place so I don't have to carry everything so far each time.
That's going to result in far more imaging time than packing everything into the car, driving out to a dark site, setting up and watching the clouds role in.
Steve.
Jeff
Jan 21, 2010 12:36 |  #4
I've thought a little about this too. My thought was to put a pier with an adapter plate in the back yard. For most of the time I'd leave the mount on the pier (aligned) and carry the OTA & accesories in and out of the garage. This should make for shorter startup times. If I want to go to my "darker" site I pack up the tripod, mount and all the extras and go.
When returning the mount to the pier I should be able to use some marks on the mount & plate and landmarks to get close to alignment.
I'd still have to think up some way to weatherproof & secure the mount while on the pier though.
Jeff
70D | Tokina 12-24 | Tamron 17-50 f/2.8 | Canon 28-135 IS| 430EX
Astrophotograpy: QHY268m, Astronomik Deepsky LRGBHaO3S2 filters, Meade 10" SCT, Astrotect 130EDT APO (.8x), iOptron CEM60 to keep it all off the ground.
MY AIRPLANE PICS (external link) | MY ASTRO PICS (external link)
Adrena1in
Jan 21, 2010 16:25 |  #5
My decision to go for a Pier is so that I have at least a half-permanent arrangement. Part of my issue is that carrying my mount and tripod to the garden each session is meaning I'm not that well aligned, and while that's been okay for lunar shots, when I do want to give DSO imaging a go I know it's going to take hours to get everything set up.
With my little EQ5 I marked the patio so I could put the tripod back in the same place each time. But then I read about how it's not great to have the scope near a house, which my patio is. Then I read it's best to have the scope over grass, to reduce heat turbulence. My tripod will just sink into the earth, so the decision to at least get a Pier would mean that I have a permanent place to mount my scope, and once it's aligned it'll remain aligned.
Security-wise I won't leave the scope on the pier, and I'll usually remove the mount too. But for times I'm home, such as at a weekend, it could remain all set up from Friday night to Sunday night, covered to protect it from the elements when I'm not using it. (And if it means I can slowly, while she's not looking, build an observatory around the pier, then all the better!!) ;)
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
chris.bailey
Joined Jul 2003
Jan 22, 2010 02:13 |  #6
Friend of mine has two lengths of telegraph pole concreted in which most of the time have bird feeders on them. They also have all the fittings on the top to put his mount onto and a waterproof power socket. Having the two gives him coverage of the sky from either side of his house. Quite a SWMBO friendly option. Trouble for me is that my driveway is the best imaging position and it might be a bit hard to move the car around with a telegraph pole in the middle.
Adrena1in
Jan 22, 2010 02:57 |  #7
chris.bailey wrote in post #9445650 (external link)
... most of the time have bird feeders on them.
A lot of time I'll remove the mount and adapter and use mine as a bird bath/food table I expect. See what you mean about having yours in the middle of your drive. I guess you could have one of those sort of security bollards that can drop down level with the ground when you're not using it!? ;)
SteveInNZ
Jan 22, 2010 03:44 as a reply to  @ Adrena1in's post |  #8
I was thinking an ornate sundial would be appropriate.
I like the adapter plate idea - That future-proofs it enough that it might be viable.
Steve.
MintMark
Jan 22, 2010 06:48 as a reply to  @ SteveInNZ's post |  #9
A sundial is a great idea... but maybe there's a way a rotary washing line can be used to help with alignment? :)
Mark
Jeff
Jan 22, 2010 07:34 |  #10
Translation please? ???
Jeff
chris.bailey
Joined Jul 2003
Jan 22, 2010 07:34 |  #11
The top-cap fixing of an EQ6 is pretty straightforward. I had played with the idea of something along the lines of http://www.altairastro​.com/product.php?produ​ctid=16169 (external link) but for a wooden pole pier you would need some additional means of levelling it.
SteveInNZ
Jan 22, 2010 14:54 |  #12
Jeff wrote in post #9446461 (external link)
SWMBO = She Who Must Be Obeyed
Steve.
Jeff
Jan 23, 2010 07:32 |  #13
SteveInNZ wrote in post #9449245 (external link)
Steve.
BWAAA Ha Ha Ha Ha! Never heard that before!
Jeff
Adrena1in
Jan 23, 2010 11:45 |  #14
Steve.
Brought my new Pier home today, took it into the hall, said, "Here y'are, it's alright, isn't it?", to which the reply was, "Hmmm, it's ugly! Going to look horrible in the middle of the lawn!" :(
Jeff
Jan 23, 2010 11:56 |  #15
Adrena1in wrote in post #9454339 (external link)
Ooops. :cry:
Hey post a picture...It can't be that ugly...to us anyway.
Jeff
4,189 views & 0 likes for this thread, 7 members have posted to it.
1563 guests, 140 members online
