Thread started 20 Jan 2010 (Wednesday) 17:09
Shadow Noise
Colin ­ Morey
Joined Nov 2005
Jan 20, 2010 17:09 |  #1
A Friend has been commenting that he sees a lot of noise in the shadows on my photos,
for example
This one, taken a ISO 100, f13 1/250
If I crank up the exposure slider in Aperture I think i can see what he's talking about, but otherwise it just looks black to me. (turning the brightness all the way up on my monitor doesn't show it up).
How does it look to people here?
1DmkIV, 350D dual zoom kit, EF-S 60mm macro(sold), 50mm 1.8(sold), 100-400mmL IS, 70-200mm f2.8 IS L IS, 10-22mm(sold), 3x580EXII, 24-70mm f2.8L
Comments and Critisms welcome, edits allowed if you tell me how you did it :) No Bird Posts Left Behind! My photo-a-day habit. (external link)Zenfolio: VPZ-MH5-2PZ
blackhawk
Jan 20, 2010 17:18 |  #2
It's underexposed, that's why there's shadow noise; not enough data to properly render the image.
You got to know when to hold 'em, know when to fold 'em
Know when to walk away and know when to run
You never count your money when you're sittin' at the table
There'll be time enough for countin' when the dealing's done
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Jan 20, 2010 17:19 |  #3
We need a 100% crop. In any case, that shot looks underexposed to me.
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
Colin ­ Morey
Joined Nov 2005
Jan 20, 2010 17:28 |  #4
100% crop,
Content warning: NOT AN IMAGE
I'm interested in the fact you say it's under-exposed,.. it's supposed to not have any detail in the background. (or the foreground, it should just have highlights)
is
any better (I've pushed the exposure 1 stops and raised the black point to compensate?
crashthenet44
Location: Rails of the Lehigh Valley Line and Trenton Sub
Jan 20, 2010 17:42 |  #5
Are you and your friends monitors calibrated? Mine are and all I can see is the knife edge and faint( and I mean faint) outline of the tip of the knife. I had to bring up the levels in PS to even figure out what I was looking at.
PS. I like the idea of the shot alot. Just needs some fine tuning.
FLICKR (external link)
http://blogspot.vision​sfromphilly.com (external link)
50D | OM-2n | OM-4T | Hasselblad 500C/M | Yashica GSN | Yashica A | NO2. Brownie Model F
Colin ­ Morey
Joined Nov 2005
Jan 20, 2010 17:43 |  #6
This is what I see on my screen, http://www.random-chaos.org.uk …-a-day-images/compare.jpg (external link)
The one on the left is the updated one, the one on the right is the original.
So i'm confused now.
vk2gwk
Gallery: 332 photos
Jan 20, 2010 17:43 |  #7
I do not see any "noise" in the 100% crop. There is some detail in the metal work but that is not noise, I think...
My name is Henk. and I believe "It is all in the eye of the beholder....."
Image Editing is allowed. Please explain what you did!
Canon R5, R,, RF24-105/1:4 + RF70-200mm F/2.8 + RF15-35mm F/2.8 + 50mm 1.4 USM + Sigma 150-600mm Sports + RF100mm F/2.8 + GODOX V860 IIC+ 430EX + YN568EXII, triggers, reflectors, umbrellas and some more bits and pieces...
Photos on: Flickr! (external link) and on my own web site. (external link)
Colin ­ Morey
Joined Nov 2005
Jan 20, 2010 17:45 |  #8
crashthenet44 wrote in post #9435838 (external link)
you should just see the edge of the end and the backbone of the knife and the scalloped teeth, otherwise it should all be pretty much black.
I could have sworn it was calibrated recently, but now I think about it, i don't remember doing it since I installed snow leopard. but it should be very, very dark as a photo, i was aiming for just an outline.
blackhawk
Jan 20, 2010 18:05 |  #9
It's shadow noise; if you push the left side of the tone curve margin too far right, you clip data causing it... and underexposure.
It's way underexposed.
Colin ­ Morey
Joined Nov 2005
Jan 20, 2010 18:24 |  #10
Looking at the .JPG (I shoot RAW+JPG) the background has smudges of grey on it.
I still don't understand how I could expose correctly for it though. The exposure was driven purely by the flash creating the rimlight on the top and left of the blade with bounced light illuminating the teeth.
I guess I'll have to set it up again tomorrow and run through the range on the flash output to see it's affect, but I didn't want to illuminate the face of the blade.
blackhawk
Jan 20, 2010 19:10 |  #11
The full size image should look ok... ummm that's a really small jpeg.
Use some noise reduction and in DPP preferences >General Settings>Jpeg image quality>enable "remove bock noise and mosquito noise"
Nathan
Gallery: 18 photos
Jan 21, 2010 00:06 |  #12
On my calibrated monitor, the left photo is much better and meets the goal that you describe.
Maybe I don't fully understand, but since this photo is mainly about highlights against a dark/black background... there aren't really any shadows to see noise in. You've reduced the blackpoint to where any noise would be effectually hidden. The jpegs are indeed very small.
To adjust for proper exposure for this type of photo, you'll have to look at your histogram to ensure that there's no clipping and that the highlights are where you want to be. The camera's meter, regardless of which metering mode, is likely to be way off for whatever you're trying to achieve considering there is so much black in the scene. That in itself can result in noise if the exposure is not where you want it to be and you have to push it in post.
Colin ­ Morey
Joined Nov 2005
Jan 21, 2010 02:20 |  #13
blackhawk wrote in post #9436394 (external link)
Here's the full size original Jpeg before crop
http://www.random-chaos.org.uk …-01-20-_MG_8002%20(2).jpg (external link)
and here's the processed version,
http://www.random-chaos.org.uk …002%20-%20Version%202.jpg (external link)
At some angles on my monitor I can make out noise in the first one, but its pretty much gone in the second.
I can't find the orignal OOC JPEG, so I'll have to double check the camera, I may have gone back to just RAW:rolleyes::rolleyes:
Colin ­ Morey
Joined Nov 2005
Jan 21, 2010 02:24 |  #14
Nathan wrote in post #9438036 (external link)
They're done just for the web, but I'm glad that you're seeing what I'm seeing (I think), my friend appears to be having problems with his computer, if he loads the image up without photoshop running it looks o.k., but as soon as he fires up photoshop, the noise appears.
I will have to check this out this evening, and see if I can get it to not clip, (I 'm still struggling to understand how I can clip black, clip white - yes, black - no). More Reading required I think.
Thanks to everyone who's commented so far, it's been really helpful.
Disturbed ­ UTT
Jan 21, 2010 03:23 |  #15
Colin Morey wrote in post #9438459 (external link)
Agreed. Quite clear to me in the first (on my NOT calibrated work monitor). Second looks fine though.
I love the idea. Would you mind sharing your setup?
Canon EOS 5D III | Canon EOS 7D | Canon EOS 400D Gripped
Canon EF 70-200mm f/2.8 III L IS USM | Canon EF-S 17-55 IS F/2.8 | Canon 50mm F1.8 mk1 | Canon 100mm F/2.8 Macro | Canon 70-200 F/4 L USM (non IS) | Canon EF 100-400mm f/4.5-5.6 L IS USM
Canon 430ex II & 580ex II
2,656 views & 0 likes for this thread, 6 members have posted to it.
Shadow Noise
1556 guests, 135 members online
