Thread started 20 Jan 2010 (Wednesday) 20:36
Flash Bracket or.....
Mr. ­ Bill
Jan 20, 2010 20:36 |  #1
Ring flash?
Which is the better and/or most cost effective route to go for someone just getting into Macro photography?
Thought about going with the Delta but I keep reading that it fails after several uses. Would like to keep costs to no more than $75 range if possible.
Thanks in advance for all suggestions.
Link to my Pictures (external link)
Martin ­ G.
Jan 20, 2010 21:02 |  #2
I had the ring flash and always disliked it, seldom used it. I sold it last summer, got a bracket and flash gun + diffuser and I love it.
So one vote for bracket as far as I am concerned. You also get a flash that you can use in regular situations as well.
Martin
6D & 70D
EF 24-105 L, EF 40mm, EF 85mm f1.8, EF 100mm L IS, MP-E 65
Macro Twin Flash MT-24EX, 430 EX II & 270 EX
themadman
Jan 20, 2010 22:15 |  #3
Flash bracket =)
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
windpig
Chopped liver
Jan 20, 2010 22:38 |  #4
flash ring if you're taking dental pics. Else, flash bracket.
Go ahead, spin the wheel.
LordV
Jan 21, 2010 00:55 |  #5
Agree with above unless you want to invest in an MT-24 which is very expensive.
I still use a bracket mounted flash.
The Hakuba LH-1 ballhead bracket (Ebay) is reasonable but you still may need to replace the ballhead with a larger generic one.
Good DIY version here https://photography-on-the.net/forum/showthre​ad.php?t=813717
Brian v.
Macro Hints and tips
dicklaxt
Jan 21, 2010 05:51 as a reply to  @ LordV's post |  #6
I purchased one of those ,mine was a steady burn not a flash and found it rather cumbersome to change the mounting ring when using a differnent diameter lens.The on camera life was only 45 minutes,however it could also be used with AC voltage by plugging into a household receptacle and could be used on the 6" tripod that came with it for aux lighting in a light box.Just a couple of pros and cons,,,,,,knowing this tho beforehand, I would not have purchased it.
dick
1,931 views & 0 likes for this thread, 6 members have posted to it.
1048 guests, 107 members online
