Thread started 21 Jan 2010 (Thursday) 21:06
Streaks on Sensor
clrv
Jan 21, 2010 21:06 |  #1
OK I have cleaned my sensor several times but have used a blower or suction. I had a few spots that would not come up this time so I used a swab. I have the kit from Sensor Scope but like I said this was the first time to use a wet swab. Anyway I get done and at first glance it looks great but closer inspection there are streaks. I have gone over it several times now and can't get them to go away. I have tried more solution, less solution nothing seems to work. The less I use 1 drop vs 2 leaves less streaks but they are still there.
Any ideas?
Gear: 5D Mk ii, 50D, Canon 15mm, 24-105L, 24-70L, 70-200L 2.8 IS, 85 1.2L, 430EX II, 580EX II
Nicholas ­ R.
Joined Jan 2005
Jan 21, 2010 21:27 |  #2
clrv wrote in post #9444265 (external link)
Any ideas?
You need to get a bottle of Eclipse, it's pure methanol/solvent and it evaporates totally in 2 or 3 seconds. Guaranteed to leave no residue, which is what you've got now. Unfortunately, that's your only option at this point. With a water-based solution, you could use only one drop and wait 30 minutes before swabbing and you'll still get streaks.
Good luck,
Nicholas
www.copperhillimages.c​om/index.php?pr=galler​ies (external link)
Lyndön
Jan 21, 2010 21:28 |  #3
Try letting the swab dry for a few seconds before you swab the sensor. I use E2 solution, and they recommend using a drop of solution, letting it dry for 10-15 seconds, then swabbing. Experiment with different drying times.
clrv
Jan 21, 2010 21:35 |  #4
Thanks guys I will have to try drying times and hope that works. I have 2 shoots Saturday and don't have time to get the Eclipse, but will get some on order.
Really hope it works
1,322 views & 0 likes for this thread, 3 members have posted to it.
Streaks on Sensor
Latest registered member is RawBytes
1497 guests, 162 members online
