Tony-S wrote in post #9453873
I think the biggest difference is that the 7D can do 720p60fps since it has two DigiC IV processors. I doubt the 5Dii will ever be able to do that. I've not seen any comparisons between the two cameras, though.
The preview for the 5dmkii firmware update showed that it could. Computationally, 720p is less than half as complex as 1080p, so there's no reason why the 5dmkii can't do 720p at 60fps, or the 7d doing more than 60fps (could probably do 1080p at 60fps). The main limitation seems to be the sensor at this point, not the processing (18mp*8fps=144mp/s, 1080p = 2mp * 60fps = 120mp/s. Throw in the fact it has hardware support for h264, and add some overhead, and you can definitely see 1080p having 60fps on the 7d).
Video wise, no, they are not the same, and putting video from both sources may lead to a desync of the audio. 5dmkii shoots in non-drop frame 30fps, 7d shoots in drop-frame 30fps (29.97, means for every 1001 frames, you only record 1000). The new firmware update should fix that whenever it comes out.
