FORUMS Post Processing, Marketing & Presenting Photos The Business of Photography
Thread started 23 Jan 2010 (Saturday) 11:23
Wedding photogs... what size files do you give?
2.8orfaster
Jan 23, 2010 11:23 |  #1
just curious, what do you size your digital negs and what DPI when you give them to your clients?
gravy ­ graffix
Jan 23, 2010 12:14 |  #2
Full size and a folder with facebook size watermark.
Dpi I leave it at 300 in lighroom.
Peoria IL Wedding Photographer (external link) Chicago Wedding Photographers (external link)
Thalagyrt
D'OH. I need to wake up some more.
Jan 23, 2010 14:55 as a reply to  @ gravy graffix's post |  #3
Ugh, not the DPI junk again. DPI is just an integer field in the image. It has nothing at all to do with how much data you're giving them. 2000x3000 pixels is 2000x3000 pixels at 1 DPI or 9000 DPI. DPI only relates to printing. It's completely arbitrary and based on the print size you want to output, and what you set it to means absolutely nothing as it has no effect on the actual image and can be changed any time by anybody.
2.8orfaster
Jan 23, 2010 16:47 |  #4
So full size huh. 21MP is a large file size. Any wedding photogs downsize their images?
harroz
Jan 23, 2010 17:25 |  #5
I don't give them to my clients, I sell them, and so they get full size jpegs @ 300ppi.
Yes, there is a difference of me passing over a 300ppi vs a 72ppi, because the client does not know how to change it, and I do not know where they're going to print it, and if they submit it to a magazine(with my authorization) then the mag is going to get a 300ppi, which is usually what they require.
blog (external link) weddings (external link) commercial (external link) mm (external link)
Borna ­ C
Jan 23, 2010 17:46 |  #6
let's keep it simple here. your picture has 5000px. if you print in on 10 inches its 500ppi, if you print in on 20 inches it's 250ppi and if you get a big fcking paper and tell a printer to print it full size than it's going to either print it 10 inches big if set to 500ppi or 20 inches big if set to 250ppi or 50 inches if set to 100ppi. since your clients will most certainly print it on a very strictly sized piece of paper, the ppi value is not important. but it still has the same 5000px however you look at it. and we are not talking about printing here, we are talking about digital data
about downsizing and file size, I'd probably go for A4 300dpi (see, I don't know how much pixels that is, but you can calculate it from the dpi value, but if I knew how much pixels it was, I would divide it with the paper size and get the dpi value). that's certainly the biggest size they'd ever print
Canon 40D + grip, Canon 400D + grip, 430EX flash, YN-460 x 3, RF-602 triggers
Canon 50mm 1.4, Tamron 17-50 2.8, Canon 18-55 f/3.5-5.6, Sigma 55-200 f/4.0-5.6
web-site (external link) facebook (external link)http://fotoidijot.blog​er.hr (external link)
tim
Light Bringer
Jan 23, 2010 22:09 |  #7
3600pixels on the longest side, for consistency between cameras. That gives them a 300ppi 8x12" print, and they can make a good 30" print as well. I also remove camera exif and insert my copyright into the exif and iptc fields using EXIFer. Also 600px watermarked so they can use them online.
5,417 views & 0 likes for this thread, 6 members have posted to it.
536 guests, 122 members online
