How long should one of these last? I'm looking to buy an apple display and I was wondering the life span on these. Or I could pic up a nice, not the cheapy, Dell monitor fir about half the price.
mutau052 Senior Member 535 posts Joined Dec 2008 Location: Edmond, OK More info | Jan 25, 2010 09:13 | #1 How long should one of these last? I'm looking to buy an apple display and I was wondering the life span on these. Or I could pic up a nice, not the cheapy, Dell monitor fir about half the price. 6D w/ BG-13, 40D w/ BG-E2N, Canon 50mm f/1.8ii, Canon 24-70 f/2.8L USM, Canon 430 EXii
mcluckie I play with fire, run with scissors and skate on thin ice all at once! 2,192 posts Gallery: 109 photos Best ofs: 2 Likes: 449 Joined Jul 2009 Location: Hong Kong, Ozarks, previously Chicago area More info | Jan 25, 2010 09:15 | #2 20 years. Dells use the same guts (on some) that Apple does. I used to have a studio with 6 20" ones, now I'm smaller and have only a 30 and 23. Wouldn't sell them for anything. multidisciplinary visual guy, professor of visual art, irresponsible and salty.
AlphaChicken Knot Hank 3,569 posts Joined Aug 2007 Location: Asheville, NC More info | Jan 25, 2010 09:49 | #3 Monitors last a long time. The one on my gaming PC (built it about six years ago) just died and I left it on all the time, plus it only cost 125 bucks. I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
Jan 25, 2010 11:06 | #4 I'm more talking about it's ability to hold true and not dim or have color issues. Has any one had any of these apple displays over 3 years and if so how is it holding up? 6D w/ BG-13, 40D w/ BG-E2N, Canon 50mm f/1.8ii, Canon 24-70 f/2.8L USM, Canon 430 EXii
dugcross Senior Member 879 posts Likes: 3 Joined Jan 2008 Location: St. Petersburg, Florida More info | My apple display at home is almost 5 years old. Still great. At work, a lot older and still looks good, granted they are calibrated every so often Doug Cross
AlphaChicken Knot Hank 3,569 posts Joined Aug 2007 Location: Asheville, NC More info | Jan 25, 2010 11:59 | #6 mutau052 wrote in post #9467016 I'm more talking about it's ability to hold true and not dim or have color issues. Has any one had any of these apple displays over 3 years and if so how is it holding up? Every monitor will slightly change over time. It is just physics. That is why you get a color calibrator. I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
basroil Cream of the Crop 8,015 posts Likes: 2 Joined Mar 2006 Location: STL/Clayton, MO| NJ More info | Jan 25, 2010 12:34 | #7 mutau052 wrote in post #9467016 I'm more talking about it's ability to hold true and not dim or have color issues. Has any one had any of these apple displays over 3 years and if so how is it holding up? Don't waste your money on the ACD. Both the 2408WFP and U2410 are rated higher in terms of quality. I've had a 2408WFP for a bit over two years now, and it's just as (overly) bright as when I got it. No tinting issues or bad pixes either. I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing.
mcluckie I play with fire, run with scissors and skate on thin ice all at once! 2,192 posts Gallery: 109 photos Best ofs: 2 Likes: 449 Joined Jul 2009 Location: Hong Kong, Ozarks, previously Chicago area More info | Jan 25, 2010 14:40 | #8 Fading and color shifting is less an issue with flat panels than older CRTs. Like I sai, if you want cheaper, look to Dell (and maybe Hp). Depends if you like plastic frames and jerky pivots. Apple has lowered its pricing to be much closer than Dell. multidisciplinary visual guy, professor of visual art, irresponsible and salty.
basroil Cream of the Crop 8,015 posts Likes: 2 Joined Mar 2006 Location: STL/Clayton, MO| NJ More info | Jan 25, 2010 17:54 | #9 mcluckie wrote in post #9468433 Fading and color shifting is less an issue with flat panels than older CRTs. Like I sai, if you want cheaper, look to Dell (and maybe Hp). Depends if you like plastic frames and jerky pivots. Apple has lowered its pricing to be much closer than Dell. Looks like you haven't used either company in a while. Dell's pivots are two axis (three DOF in some models like the 2408WFP) and counterbalanced (also supports VESA mounting). Apple has one pivot, so can't use it portrait mode without buying a (non-VESA, since it isn't supported, mounting bracket). Both companies make the monitors using a metal frame with a polymer (Apple uses a glossier surface than dell does for most monitors) outer shell. Stylistically, the monitors are quite different, but the quality is top notch with both. I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing.
AlphaChicken Knot Hank 3,569 posts Joined Aug 2007 Location: Asheville, NC More info | Jan 25, 2010 17:56 | #10 basroil wrote in post #9469758 Looks like you haven't used either company in a while. Dell's pivots are two axis (three DOF in some models like the 2408WFP) and counterbalanced (also supports VESA mounting). Apple has one pivot, so can't use it portrait mode without buying a (non-VESA, since it isn't supported, mounting bracket). Both companies make the monitors using a metal frame with a polymer (Apple uses a glossier surface than dell does for most monitors) outer shell. Stylistically, the monitors are quite different, but the quality is top notch with both. I have to agree. Apple displays are nothing super special. If anything, dell's monitor series looks as good if not better. I also like the black matte frame of the dell monitors more than the silver/white of apple. I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
tepic Member 233 posts Joined Oct 2008 Location: Seattle More info | Jan 25, 2010 18:11 | #11 basroil wrote in post #9467496 Don't waste your money on the ACD. Both the 2408WFP and U2410 are rated higher in terms of quality. I've had a 2408WFP for a bit over two years now, and it's just as (overly) bright as when I got it. No tinting issues or bad pixes either. Not only that, but from the ACD's that I've seen, you can't turn the brightness down to a point where it doesn't hurt your eyes. Can't be good for proofing the whiteness of paper either.
AlphaChicken Knot Hank 3,569 posts Joined Aug 2007 Location: Asheville, NC More info | Jan 25, 2010 18:23 | #12 tepic wrote in post #9469867 Not only that, but from the ACD's that I've seen, you can't turn the brightness down to a point where it doesn't hurt your eyes. Can't be good for proofing the whiteness of paper either. Can you not turn the brightness of the back-light down from within a mac though? I am pretty sure I can on my laptop. I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
basroil Cream of the Crop 8,015 posts Likes: 2 Joined Mar 2006 Location: STL/Clayton, MO| NJ More info | Jan 25, 2010 18:26 | #13 AlphaChicken wrote in post #9469940 Can you not turn the brightness of the back-light down from within a mac though? I am pretty sure I can on my laptop. That would be a deal negation for me right there if true that you couldn't and if I were making the purchase decision. You can, but not enough to get to the recommended 120 I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing.
AlphaChicken Knot Hank 3,569 posts Joined Aug 2007 Location: Asheville, NC More info | Jan 25, 2010 18:28 | #14 basroil wrote in post #9469955 You can, but not enough to get to the recommended 120 Lame... obviously OP do not get the apple then. I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
mcluckie I play with fire, run with scissors and skate on thin ice all at once! 2,192 posts Gallery: 109 photos Best ofs: 2 Likes: 449 Joined Jul 2009 Location: Hong Kong, Ozarks, previously Chicago area More info | Jan 25, 2010 19:00 | #15 Not only that, but from the ACD's that I've seen, you can't turn the brightness down to a point where it doesn't hurt your eyes. Can't be good for proofing the whiteness of paper either. Of course you can. multidisciplinary visual guy, professor of visual art, irresponsible and salty.
| Latest registered member is Mihai Bucur 1195 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
