Thread started 25 Jan 2010 (Monday) 11:15
How to accomplish 100% crop?
snowshine
Jan 25, 2010 11:15 |  #1
Hi,
I have Canon 40D.
I take photos in RAW.
I process the photos in Aperture 2 in MAC computer.
This has cropping facilities. However on few different occasions in here in the forum I see talk about 100% crop. What does that mean & how to accomplish that?
Regards
stsva
Gallery: 45 photos
Jan 25, 2010 11:32 |  #2
A 100% crop is made by displaying the image in an editing program at 100% view, then cropping a portion from that without resizing/re-sampling the cropped portion of the image. For example, you have a 1000X1000 pixel image displayed at 100% view, and crop a 150X150 pixel section; that cropped section would be a 100% crop because it shows that section of pixels from the larger image at 100% view.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jan 25, 2010 14:24 |  #3
That is when you open your photo in Photoshop (or other editing program), and then without resizing the shot, you use the "Rectangle Selection Tool" and select an area. Once you have an area, you then crop away every thing other than the selection by using the Image>Crop Command. For the purpose of posting here, you want the selection to have a longest dimension of no more than 1024 pixels.
The resulting image is called a "100% Crop". Because 1) its resolution is at 100% of the native shot - neither resized up nor down, and 2) it is a Cropped portion of a larger shot.
When you post a 100% crop, the primary purpose is to show the native sharpness (or lack of sharpness), or to draw attention to a certain area of a shot. A 100% crop is not usually meant to be a final image for printing.
So, in this shot, the first image is a "100% crop" of the area in the red square from the second image. These were originally posted to show the noise characteristics of the 5dMkII at 3200 iso. The bottom, "full" shot is just the jpg taken out of the camera and then reduced in size for display here, as Tony said, so you can see the whole image on your monitor.
BEFORE I minified the image, I used the rectangle selection tool and cropped out just the portion seen in the first image here. That way, the viewer can see a "full sized" - or "one for one mapping", or "100%" look at a portion of the shot.
Hope that this helps.
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
snowshine
Jan 25, 2010 14:31 |  #4
Hello Radtech & stsva,
Wonderfully explained.
Thanking you
mcluckie
I play with fire, run with scissors and skate on thin ice all at once!
Gallery: 109 photos
Jan 25, 2010 14:49 |  #5
Doesn't that mean NO crop, as in what you framed is what you're done with...
multidisciplinary visual guy, professor of visual art, irresponsible and salty.
Leicas, Canons, Hasselblads
all and historic dingus
stsva
Gallery: 45 photos
Jan 25, 2010 14:51 |  #6
mcluckie wrote in post #9468502 (external link)
That would be logical, but it's not how the term "100% Crop" is used in practice. :)
Member of the GIYF
Club and
HAMSTTR
Image Editing OK
Quad
Joined Nov 2005
Jan 25, 2010 16:40 |  #7
There is a word missing. It should be "a 100% view crop" the 100% referes to the view part; the crop makes it possible to put it on the forum.
1,609 views & 0 likes for this thread, 5 members have posted to it.
1042 guests, 116 members online
