Thread started 25 Jan 2010 (Monday) 14:13
Does 50D focus better or faster with f2.8 lenses?
mshill
Jan 25, 2010 14:13 |  #1
Let me preface this with I have had my 50D only a few months and I previously had a 20D. I took up photography when my daughter took started cheerleading at 8 yrs old. Since I had to sit through Youth Football games and Cheer Competitions I needed something to keep me from poking my eyes out from boredom.
Now to the meat of the question... I have been shooting a lot of indoor competitions for 3 years now and always shoot with a 70-200/f2.8L. In the past I have avoided shooting wide open because of the lens being ever so slightly softer. In the past I have tried to keep it a f3.2 or f3.5 to keep the shutter speed at least 1/250.
This weekend the lighting in the San Jose convention center was horrid so I had to shoot ISO1600, 1/250, f2.8 and was still probably a half stop underexposed. The 50D has never performed better. Very few shot were discarded due to missed focus, and I am sure some of those can be attributed to my technique and the general speed that I was switching targets. Even a couple weeks ago, in much better lighting, when I shot ISO800, 1/320, f4 I did not get as consistent results as I did this last weekend.
I always use shoot manual with custom white balance, center focus point. Focus distances range from probably 4 meters to 20 meters and I use One Shot on the * button. Hit * and rattle off a burst, go to next target and repeat.
So, at f2.8 does the 50D focus faster or more accurately?
50D, Tamron 28-75 f2.8, Canon 70-200 f2.8L, Kenko 1.5x Extender, Sigma EF-500 DG ST + Fong Dong
muusers
Joined Sep 2009
Jan 25, 2010 14:16 |  #2
Actually, if you set your aperture to f16, you still be focussing at f2.8...
De 50D does AF better due to his crosstype AF-sensors, which are activated using f2.8 or faster lenses,
50D + 17-55 | s100 | flickr (external link)
Duncan ­ Frenz
Purposely evaded the TF
Jan 25, 2010 14:19 |  #3
The camera focuses with any lens at its largest aperture. With a f/2.8 it will enable the extra sensitivity of the center focal point on the 50D, regardless of the actual aperture of the resulting image. In other words, you get the benefit of the better AF with any lens f/2.8 or faster, regardless of the desired aperture.
- Duncan
Gear_Mor
e than I need, Less than I want
Nonconformists are all alike.
I am not an expert, but I play one on the internet.:D
BigBlueDodge
Jan 25, 2010 15:46 |  #4
So as the others have indicated, your 50D does focus better with a lens who's maximum aperture is f/2.8 or wider. (What you actually take the picture at, such as f/4.0, 5.6, 8.0, etc is irrelevant). But what does this actually mean. For lenses that are slower than f/2.8 (i.e f/4.0, f/5.6), AF accuracy is guaranteed to be somewhere within the DOF of the lens. That means that if your DOF is 4 inches, using the chosen aperture value and shooting difference, then your lens will achieve focus somewhere within that 4 inch space. So if you put your AF point on your subject, the focus area will be within a 4 inch window of your AF. It could mean that the focus is 2 inches in front of your AF point, or maybe 2 inches behind it, or best case, directly on the AF point.
When you use a f/2.8 or faster lens, the additional light allows the camera to increase the accuracy to 1/3 of the DOF. So using the scenario above with a 4inch DOF, a f/2.8 lens will increase your focal accuracy to 1.33 inches from the AF. In this scenario, with a fast lens, your 50D should focus within .67" inch of your AF point (forward or backwards). The additional light that fast lenses provide help enable the AF sensors to make smarter decisions, as they can "see" more.
David (aka BigBlueDodge)
Gear
hpulley
Jan 25, 2010 15:58 |  #5
The 1D's have more than one special f/2.8 AF sensor but the rest have only one in the center.
flickr (external link) 1DIIN 40D 1NRS 650 1.4xII EF12II Pel8 50f1.8I 28-80II 17-40L 24-70L 100-400L 177A 199A OC-E3 RS-80N3
apersson850
Gallery: 35 photos
Jan 25, 2010 17:25 as a reply to  @ hpulley's post |  #6
On the other hand, a camera like the 7D has 19 cross-type sensors and a 50D has nine cross-type sensors at f/5.6.
A 1D Mark IV has zero.
Anders
hpulley
Jan 25, 2010 21:52 |  #7
The 1D IV has 39 cross type sensors for f/2.8 but you're right, for f/5.6 it has none. The 1D is a pro camera meant for fast pro lenses. It does have an f/8 sensitive center AF point (horizontal only but better than nothing).
mshill
Jan 26, 2010 01:17 as a reply to  @ hpulley's post |  #8
So, since I was shooting with an f2.8 lens at differnt aperatures there should have been no difference between hitting focus at f4 and f2.8. It must have come down to technique. When I was shooting f4 I was standing and when shooting f2.8 (getting better focus accuracy) I was kneeling on one knee.
apersson850
Gallery: 35 photos
Jan 26, 2010 02:03 |  #9
hpulley wrote in post #9471247 (external link)
True, and as long as you have all at least f/2.8 lenses, there's no problem at all. But at f/5.6, or even f/4, it doesn't have much of an advantage over the 7D.
Anders
hpulley
Jan 26, 2010 05:11 |  #10
apersson850 wrote in post #9472462 (external link)
Horizontal-line only sensors are not useless. People disparage the Rebels as only having one useful AF sensor but this is not really the case. The 45 AF sensors on the 1D, even if only horizonal line sensitive due to a slow lens, still provide more coverage and thus composition advantages but you're right that the 1D is best served by lenses to match it. Most sports pros who use a 1D body will also use the big expensive f/2.8 lenses to get good shutter speeds anyways.
The center point of the 1D is also good for AF to f/8 so there is an advantage there when using teleconverters. You have to goof around with tape and suffer very slow AF on the other bodies to get AF at all at f/8.
apersson850
Gallery: 35 photos
Jan 26, 2010 08:01 as a reply to  @ hpulley's post |  #11
I agree with everything you say, but I have the feeling that far from everyone know about it. That's why I posted.
Anders
Chris_R
Gallery: 40 photos
Jan 26, 2010 08:14 |  #12
And how is handled the f/1.2 on such sensors? :o
Canon 1DXII | Canon 7D + BG-E7
EF 16-35 f/4L IS USM | EF 24-105 f/4L IS USM
EF 70-200 f/2.8L IS USM | EF 100-400 f/4.5-5.6L IS II USM
EF 50 f/1.2L IS USM | EF 85 f/1.4L IS USM | EF 100 f/2.8L IS USM Macro
EF 2x II Extender | EF-S 60 f/2.8 macro
flickserve
Jan 26, 2010 10:41 |  #13
mshill wrote in post #9472292 (external link)
Camera shake when standing, even with the slightly higher shutter speed to try and compensate. Time to get the IS version - I had the same problem before i.e. shutter speeds not quite high enough to compensate for my own technique. IS can help, even at 1/250th or 1/320ths
hpulley
Jan 26, 2010 10:44 |  #14
Chris_R wrote in post #9473484 (external link)
Same as f/2.8.
Chris_R
Gallery: 40 photos
Jan 26, 2010 10:59 |  #15
hpulley wrote in post #9474335 (external link)
Same as f/2.8.
Okey, just realized that the meaning of "f/2.8 or faster" huh.
2,462 views & 0 likes for this thread, 8 members have posted to it.
1124 guests, 110 members online
