Thread started 25 Jan 2010 (Monday) 19:36
Mix and match batteries.
Pmolan
Jan 25, 2010 19:36 |  #1
I have a BG-E2N with (2) generic 2000 mAh batteries. I also have the original 1390(I think) mAh battery. Can I use a 2000 with a 1390 without anything bad happening?
If I am about to run out and I have a fully charged and a 1/2 charged battery and threw them in there, also anything bad?
EOS 50D | 17-55 f/2.8 IS | 70-200 f/2.8 IS L | 100mm f/2.8 macro | 580EX | 430 EX | 430 EZ | Team Buff!!
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jan 26, 2010 08:30 |  #2
Pmolan wrote in post #9470356 (external link)
That is not a problem. Canon battery grips are designed to draw from the stronger battery first until it's at the level of the weaker battery. Then it alternate between the batteries (a few shots from each at a time), drawing them down evenly.
Pmolan
Jan 26, 2010 12:43 |  #3
So youre saying that the batteries are not just simply working in parallel? Thats good to know.
neilwood32
Jan 26, 2010 16:44 |  #4
Nothing bad will happen - even shooting on a single battery is possible on the grip.
As RDkirk has said, the camera will just alternate between them drawing both down approx evenly.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
Pmolan
Jan 26, 2010 17:16 |  #5
Do knock off brands have this feature?
930 views & 0 likes for this thread, 3 members have posted to it.
909 guests, 145 members online
