Thread started 26 Jan 2010 (Tuesday) 01:49
HS Gymnastics
Big ­ K
Jan 26, 2010 01:49 |  #1
My first gymnastics meet of the season. Lighting was about what you would expect for gymnastics. The biggest problem was they had replaced several lights so the color temperature from light to light was radically different so fixing them in post was a joy and probably could have done better than what you see here but I am tired and going to bed.
Mark III, 85 f/1.8 - ISO 3200 1/800 f/2
Noise Ninja with the specific Mk III profile and no sharpening then a bit of USM in Photoshop to finish them up.
1
IMAGE: http://www.ks-images.com/POTN/017/7A9G9074.jpg
2
IMAGE: http://www.ks-images.com/POTN/017/7A9G9152.jpg
3
IMAGE: http://www.ks-images.com/POTN/017/7A9G9307.jpg
4
IMAGE: http://www.ks-images.com/POTN/017/7A9G9313.jpg
5
IMAGE: http://www.ks-images.com/POTN/017/7A9G9414.jpg
6
IMAGE: http://www.ks-images.com/POTN/017/7A9G9457.jpg
7
IMAGE: http://www.ks-images.com/POTN/017/7A9G9549.jpg
8
IMAGE: http://www.ks-images.com/POTN/017/7A9G9765.jpg
Follow my daily work at www.ks-images.com (external link) and feel free to C&C anything I post.
More money than skill - but I'm working on it
FlyingPhotog
Cream of the "Prop"
Jan 26, 2010 01:56 |  #2
Good action captures but IMO, you've gone just a bit overboard with NR...
A little grain isn't a deal breaker.
Jay
Big ­ K
Jan 26, 2010 02:05 |  #3
FlyingPhotog wrote in post #9472436 (external link)
Thanks for the feedback. Do they all look cooked to you or do certain ones stand out?
I need to get more practice with subtile use of NN at 3200 so this would be a good chance to do some practice.
Thanks again.
FlyingPhotog
Cream of the "Prop"
Jan 26, 2010 02:06 |  #4
1, 2 and 7 are the most "cooked"
The faces are nearly portrait-ishly over smoothed.
Jay
Big ­ K
Jan 26, 2010 02:11 |  #5
FlyingPhotog wrote in post #9472471 (external link)
Thanks. I will work on those tomorrow, or today since it is the middle of the night here.
emtp563
Jan 26, 2010 02:50 |  #6
Agreed, too much NR. I'm surprised at how good they look using the 85 1.8 though. I've never had much luck with that lens.
One thing you can try (although you probably need a Tv of 1/800th and using an Av of 1.8 might not be a good idea with that lens) is shooting RAW and overexposing a third to a half-stop then bringing it back in post. Take a look at this: http://www.usa.canon.c​om …ArticleAct&arti​cleID=1407 (external link)
Also, you can try a PS plugin specifically designed and optimized for the Mark III called Flex NR. It was made by one of the potn forum members here. You can find it in the RAW/PP section of the potn forums HERE: https://photography-on-the.net/forum/showthre​ad.php?t=680947
*cameras: Canon 1D Mark III | Canon 1D Mark II | Canon 1D "Classic" | Canon S95
*lenses: Canon 16-35L f/2.8 | Canon 24-70L f/2.8 | Canon 70-200L f/2.8 IS | Canon 1.4x TC II
*accessories: Canon 580EX II/430EX | Quantum Turbo SC | CP-E4
http://www.cyclingcapt​ured.com (external link)
http://www.facebook.co​m/cyclingcaptured (external link)
run53
Jan 26, 2010 11:16 as a reply to  @ emtp563's post |  #7
I like the action. Especially #4 on the beam. That's a tough one to get.
I am also impressed with the lighting you have to work with in that gym. My typical config for gymnastics is 40d/85mm at f2.0, 1/320, 3200. In a couple of gyms I can get to 1/500 but 1/800 would be a dream.
Canon 40D* Canon XT * Canon 430EX II * Canon 85 f/1.8 * Canon 70-200 f/2.8ISL * Canon 18-55 IS * Manfrotto 3021XPROB w/488RC2
Big ­ K
Jan 26, 2010 12:27 |  #8
I messed around with different things and in the end, was not able to find a combo that I thought knocked down the noise without still giving them that plastic skin look. If I got them to not look like dolls, there was so little NR involved it didn't seem worth even running through NR.
Attached are two versions of #2. The first is as posted and the second is with no NR at all. I would be curious your opinion of the one with no NR.
Original posted image
No Noise reduction
Content warning: NOT AN IMAGE
emtp563 wrote in post #9472599 (external link)
Thanks for the response.
Actually, these are shot about +1/3 and in RAW. That is how I normally shoot anyway. This particular location is tough to push too much. There is an indoor track around the outside and they have put lights over it that are about 10 feet out from the wall and they just blow out the wall if you push the exposure much at all.
As a positive however, it really keeps the overall noise down since the background stays so bright.
The 85 sure is a finicky lens and I do end up with lots of trashed images but would rather have fewer good images than more marginal images if I went to any of the f/2.8 lenses. I also love the 135 f/2 but it is too tight for a lot of the gymnastics stuff and the DOF is even more unforgiving.
run53 wrote in post #9474556 (external link)
Thanks. I saw her working on that move during practice so was able to be in that spot before she started her routine. It was probably my favorite of the night just because it was a bit different than the rest.
When they replaced the bulbs I mentioned earlier it really helped this location in terms of shutter speed. Last year in this same location it was 1/500 max. Just wish they would have replaced all of the bulbs so the color would have been a bit more consistent. However, I will live with color variations for the extra shutter speed.
Dan-o
Jan 26, 2010 12:43 |  #9
I like the no NR one Kevin. I rarely use it any more and agree with Jay that a little noise is better then the plastic look. Have you tried cropping #4 to get rid of the coach or is it revealing too much noise to do so. Cool shot. The best way to handle this in the future is to buy a MIV :p
Danny.
DMunsonPhoto (external link)
Cycling Illustrated (external link)
FaceBook Page (external link)
Big ­ K
Jan 26, 2010 12:55 |  #10
Dan-o wrote in post #9475184 (external link)
Thanks Danny. After messing with it, I am giving up on NR except in really bad situations. The input here sold me on it.
I left the coach in that shot only because the coach is also her mom and cropped it more with a specific sale in mind. Otherwise she would have been cropped away. The noise was not too bad but it was just a touch soft with a heavy crop due to the really shallow DOF and high ISO. Not bad really but I have been doing so much strobed work recently, I think all my 3200 images look like garbage.
I am just waiting on my Mk IV to make it to my camera store. I am next on the list. :-)
Lacks_focus
Jan 26, 2010 14:33 as a reply to  @ Big K's post |  #11
I'll add my plug to the Flex NR script for Neat Image. I just started using it. I was using Noiseware Pro. Flex NR reduces the colored speckles that make the Mk3's high ISO stand out. When I compared the same image side by side, one with Flex / Neat Image and one with Noiseware, it was pretty obvious that Flex NR retained much more detail. You still see "grain", but not the colored specks that tend to stand out (in my eye). More "film like" IMHO.
These two are just batched in both NR and then my own post processing action. The only attention paid to any individual image is crop and straighten. I’m just starting to use Flex NR, so improvement to the process in order, but I'm happy so far.
ISO 3200 through the glass.
IMAGE: http://lacks-focus.smugmug.com/BCL-Hockey-2009-2010-Season/BCL-vs-Rockey-Hill-RHAM/DLEV5012/773313511_nere7-XL-1.jpg
ISO 6400. 1/200 @ f/2.8!!! So don't kill me for the blur...
IMAGE: http://lacks-focus.smugmug.com/Coventry-HS-Gymnastics-2009/Coventry-RHAM-vs-Farmington/DLEV4632/773447456_AtppH-XL-1.jpg
1D MKIII | FujiFilm X10 | 24-70 f/2.8 | 70-200 f/2.8 | 135 f/2 | 85 f/1.8 | 580EX |
lacks-focus.smugmug.com (external link)
Big ­ K
Jan 26, 2010 14:44 |  #12
Thanks for the suggestion. I had not heard of that app so will have to check it out. That is a pretty nice shot of action at 1/200.
FlyingPhotog
Cream of the "Prop"
Jan 26, 2010 14:53 |  #13
Big K wrote in post #9475053 (external link)
No Noise reduction
It's not what I would call "God Awful" really. Perhaps a light wash through NN but cut the processing by about 1/3 to 1/2 of what you did originally.
Jay
Zivnuska
Gallery: 72 photos
Jan 26, 2010 16:57 |  #14
FlyingPhotog wrote in post #9476120 (external link)
My preference would be for "light" NR. Split the difference.
It will be interesting to see if the Mark IV changes the game on this.
www.zivnuska.zenfolio.​com/blog (external link) = My Blog
www.zivnuska.zenfolio.​com (external link)
"It's not tight until you see the color of the irides."
Big ­ K
Jan 26, 2010 19:20 |  #15
Zivnuska wrote in post #9477011 (external link)
Thanks Phil.
I can't imagine the MkIV won't. Reading a story on sportsshooter about PR Miller and how SI ran a 4000 ISO heavy crop image, it has to be a step up in performance.
2,973 views & 0 likes for this thread, 8 members have posted to it.
HS Gymnastics
2816 guests, 157 members online
