Thread started 26 Jan 2010 (Tuesday) 04:46
Does anyone use(d) an MPE-65 on entry level body?
Warl0rd
Jan 26, 2010 04:46 |  #1
I want the MPE-65 more and more, but I'm a bit worried about using it on my current body (XSi - 450D), due to the viewfinder size. With the 100mm and the tubes it gets a bit hard to see where the DOF is, the viewfinder isn't very big and bright.
I follow macro work from several photographers who use that lens, and they all have on thing in common, they use XXD or XD bodies.
So...should I switch body before moving to the MPE-65?
I can't deny the 7D looks good :lol:
Paulo
http://www.flickr.com/​photos/warl0rd (external link)
Canon 450D (XSi) + Grip | Canon 80D | EF-S 10-22 | EF 24-105 L IS | EF 100mm Macro | MP-E 65mm 1-5X | EF-S 18-55 IS STM | EF-S 55-250 IS | Takumar 55mm 1.8 | MT-24EX | Metz 48-AF1 | YN460 II | Kenko DG Auto ET | Kata 3N1-20 DL | Lowepro SlingShot 100 AW | Mitsai JDC195 | Manfrotto 190XPROB + 484RC2
tim
Light Bringer
Jan 26, 2010 05:09 |  #2
I don't have a 450D or anything like it here, but head to head between a 40D and a 7D the viewfinder's maybe 10-20% bigger on the 7D, max. I don't find the viewfinder shows DOF well, most things are in focus to my eye even with an F1.4 lens, so I have to rely on AF (99.9% of the time) or going backward and forward until I find the center point between where it's out of focus either side (if that makes sense).
irispatch
Jan 26, 2010 05:27 |  #3
Best person to ask is the master himself Lord V. He can tell you much more about the use of the MPE-65 than anyone on this board.
Canon 50D, Canon 100mm f/2.8 IS L, Canon 20-35mm f/2.8L, Canon 70-300 f/4-5.6 L IS and Kenko 1.4 TC :lol:
Gitzo G2228 with a Markins Q3, and assorted gadgets. :)
The Iris Patch
weeatmice
Jan 26, 2010 05:50 |  #4
Macrojunkie (google/flickr) uses it on an XTI I think, with great results.
FS: UK: 1D Mark IV.
Twopixel.co.uk (external link) | 500px (external link) | flickr (external link) | Twitter (external link) | Pinterest (external link) |
LordV
Jan 26, 2010 06:00 |  #5
Don't think there's too much advantage of the viewfinder on the more expensive bodies apart from being a bit brighter. Oddly the focus point with an MPE-65 lens is almost easier because the DOF is so thin at higher mags. As commented above Macrojunkie uses an MPE-65 on a 400D body.
Brian V.
Macro Hints and tips
Warl0rd
Jan 26, 2010 09:12 as a reply to  @ LordV's post |  #6
can we rely on AF confirmation with the MPE-65?
my experience with 100mm + tubes is no :(
Paulo
LordV
Jan 26, 2010 13:24 |  #7
Warl0rd wrote in post #9473757 (external link)
No - there is no AF at all with the lens.
Warl0rd
Jan 26, 2010 14:07 as a reply to  @ LordV's post |  #8
I think I'm gonna contact him and ask the question. I never tried macro with a pentaprism viewfinder, but for general use (on a 40D) I recall it was considerably bigger and brighter then my pentamirror...
Paulo
Choderboy
I like a long knob
Gallery: 185 photos
Jan 28, 2010 16:14 as a reply to  @ Warl0rd's post |  #9
I don't see the need to get the new body. You want an MP-E , buy one. Try it on your body. See what you think. Then you have the option of buying a new body.
See anything wrong with that logic?
Dave
Image editing OK
themadman
Jan 28, 2010 21:06 |  #10
Choderboy wrote in post #9492318 (external link)
Or if you don't like it you can gift it to me! I'll pay shipping and take you out for a drink! =)
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Warl0rd
Jan 29, 2010 15:36 |  #11
buying the MPE-65 isn't the same as buying the MPE-65 + body at the same time. we are talking about more then twice as much...
Paulo
DQE
Jan 29, 2010 20:20 |  #12
If viewfinder darkness is a major concern, you can use an auxiliary focus assist light, which I find to be especially helpful at higher mags. It isn't bright enough to affect the photos at ISO 100-200, even with my very high-intensity 3-watt/80 lumen LED flashlight. I use 2 rechargeable Eneloop AA NiMH batteries, good for at least 1 hour of continuous use in this flashlight.
I find that most bugs do not react much to this very high-intensity light, which I hold in my left hand pressed against the lens barrel. They instead mostly react to dark shadows. If anything, they seem to become briefly paralyzed by the flashlight. This helps you see the finest detail in the viewfinder.
I hope this option helps. I gather that most of the best macro photographers don't use a focus assist light routinely, but perhaps it's worth trying as an ordinary mortal. They cost 25-50 US dollars online with these specs if you shop around - no need for the very expensive police/military flashlight models. The inexpensive Chinese models work fine, or at least mine does - it's by Mallory, purchased at Wal-Mart. Having at least 80 lumens output (3 watts) is helpful.
--Phil
Canon gear: 5D MkII, 5D, MPE-65, 100 mm 2.8 macro, 85 mm f1.2 L, 16-35 mm f2.8, 24-105 mm L, MT-24, MR-14; 550EX flash (2 units); Gitzo 2548 tripod; Gitzo monopod; Acratech Ultimate Ballhead; Manfrotto 410 geared tripod head; Cognisys StackShot rail & controller
MrContact
Jan 29, 2010 22:57 |  #13
I use the Rebel T1i 500D (If I recall correctly) with my MPE lens. If you are having trouble with the viewfinder, switching the mode so the picture is seen on the little screen can help out alot in lower light situations. using a half-press will activate flash view mode, and it will brighten up the entire screen more then enough for a clear shot to be taken.
Of course by the point you need to activate the screen, you will need a decent flash to get a great shot out of it.
One thing I always like to repeat is the Glass before Bodies rule. Bodies can come and go, but a good piece of glass will last you a long time.
flickr (external link) ~|~ http://aperturebacon.c​om (external link) ~|~ Gear List ~|~Special Flickr  (external link)
racketman
Gallery: 20 photos
Jan 30, 2010 11:55 |  #14
I had the MP-E whilst I was still using the 350D, no problems at all.
Toby
orionmystery
Jul 16, 2013 01:59 |  #15
Not entry level DSLR but a very very old one, 40D.
Kurt
Malaysia & Borneo herping/macro tours:
http://www.orionherpad​venture.com (external link)
3,606 views & 0 likes for this thread, 12 members have posted to it.
1093 guests, 118 members online
