Thread started 26 Jan 2010 (Tuesday) 23:53
20D as good as 40D at high iso?
absolutic
Jan 26, 2010 23:53 |  #1
Hi.....I am a former Canon 40D user. After owning 40D for a while, I sold all my Canon gear and went to the dark side. Actually I had both N and C gear at the same time, and then I decided that it was too costly to continue buying gear from both mfrs. I liked and I still do the button placement, the menus, on my D300 better than that on 40D, it all felt more natural and logical to me, and the 53-point-auto-focus system does not hurt either.
Of course, as time went by, I started missing my Canon gear. And now I have a chance to pick up a 20D body for very very cheap. I am thinking about getting into Canon gear again with this 20D body.
So I am going backwards from 40D to 20D.
However, when I compared samples, reviews, etc, on 20D vs 40D, other than smaller screen, and 5fps vs 6.5fps, it does not sound like there is a big difference. I often shoot at high ISOs and I did not observe from the samples I've seen that Canon 40D significantly improved low light capabilities over 20D. Despite the fact that 20D uses Digic2 chip and 40D uses Digic3.
The autofocus system seems practically the same. Battery life seems the same (same battery). Built-in flash seems the same.
Am I missing something here, is there any reason I should pass on picking up an older 20D body? Will a former user of 40D be disappointed with high ISO on 20D?
my youtube https://www.youtube.co​m …b_confirmation=​1%5B%2Furl (external link)
Latest POTN feedback https://photography-on-the.net …=15934524&postc​ount=39869
https://photography-on-the.net …=16930253&postc​ount=43618
Chris1le
Joined Aug 2003
Jan 27, 2010 00:09 |  #2
Loved my 20D. If I hadn't broke it I'd most likely still be shooting with it. I thought that instead of getting another used 20D that I would move to the newer technology and bought 40/50D. Should have bought a used 20/30D.;) Yes, Personally I feel the 20D is better than 40D at high ISO
My Pictures (external link) : My Gear (external link)
I Reject Your Reality And Substitute My Own - Adam Savage
mshill
Jan 27, 2010 00:45 |  #3
I have not had a 40D but I used to have a 20D and now have a 50D. I have read all the threads about 40D being better at High ISO than the 50D but no direct experience. The 50D is at least 1 stop better than the 20D maybe 1.5 stops. Keep in mind that the 40D is higher resolution so you can't really compare at 20D crops at 100% to 40D crops at 100% to determine which is handling it better.
50D, Tamron 28-75 f2.8, Canon 70-200 f2.8L, Kenko 1.5x Extender, Sigma EF-500 DG ST + Fong Dong
tkbslc
Jan 27, 2010 00:47 |  #4
Unless you like poring over 100% crops, you won't really be able to tell. The AF system and LCD screen will be big changes, though.
Taylor
EOS Rp | iPhone 11 Pro Max
absolutic
Jan 27, 2010 01:34 |  #5
tkbslc wrote in post #9479915 (external link)
Oh the AF system is not the same as on my old 40D? I thought it was
Chris1le
Joined Aug 2003
Jan 27, 2010 02:06 |  #6
I must have the worst Canon corrected 50D ever. Still think 20D was better than both 40&50D. The LCD screen will do nothing for IQ.
gcogger
Joined Mar 2003
Jan 27, 2010 03:22 |  #7
absolutic wrote in post #9480052 (external link)
No, the AF system was slightly tweaked for the 30D (although it's apparently not a big change) and then improved significantly for the 40D.
Graeme
My galleries (external link)
Keith ­ R
Jan 27, 2010 04:09 |  #8
The 40D is much better at high ISO than the 20D/30D.
JeffreyG
Gallery: 42 photos
Jan 27, 2010 05:27 |  #9
When viewed in prints of like size, the 20D, 30D, 40D, 50D, XTi (400D), XSi (450D), and Ti1 (500D) all have about the same noise levels.
Be careful of the phenomenon here at POTN that people expect newer cameras will automatically have better noise characteristics. There is also some cognitive dissonance that makes people assume that their newer camera must be better than some older model.
I have shot and used files from a Rebel XT (350D), 30D (same as a 20D), 40D, and 50D. The noise looks the same. If one of these stands out as different it is the XT (350D) which is a little worse. There might be a 1/2 stop total difference from the XT to the 50D.
Worth pointing out in this thread, the 20D and 30D are nearly the same camera. The only differences are that the 30D added spot meter, a larger LCD and RGB histograms.
Going from the 30D to the 40D the main change is the AF system, which got a lot better with the 40D. The viewfinder of the 40D/50D is also a little bigger.
DStanic
Jan 27, 2010 06:37 |  #10
If you find a 20d for very very cheap why not flip it and make some money to put towards your current Nikon system?
Not saying you "shouldn't" buy Canon just having 2 systems seems redundant (unless you were buying a different kind of camera, like Olympus EP-1 which is very small)
I would have to agree with Jeffrey that i don't think there is a huge difference in noise between crop bodies. Anything from 20d-50d, XTi-T1i will be quite close (7d being a bit better), with some of the higher megapixel cameras possibly having an advantage of "shrinking" the noise when you downsize the pics. 20d-40d is only 2mp though, hardly noticeable difference.
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
Trique ­ Daddi
Jan 27, 2010 06:41 |  #11
I have both the 20D & 40D and haven't noticed any difference in noise. The 40D is faster and the AF is better without a doubt. Honestly, though I don't shoot at 1600 ISO often at all!
Canon 7DMKII,7D 40D, 20D, CANON 100-400mm IS 4.5/5.6L, Canon 70-200mm 2.8L, Canon 50mm 1.8, Canon 100mm 2.8 macro, Kenko Extension Tubes, Sigma 17-50mm F2.8 EX DC OS, 580EX II Flash,Gittos MH 5580 monopod, Thinktank Airport Takeoff.
mmahoney
Jan 27, 2010 06:48 |  #12
gcogger wrote in post #9480400 (external link)
Canon's marketing material may state an improvement but in actual practice there is certainly no "significant" improvement in 40D focus over 20D. Much the same AF performance with the two bodies in my experience.
Newfoundland Wedding Photographer (external link)
JFusion
Jan 27, 2010 07:37 |  #13
I noticed a noticeable improvement in AF going from the 20D to 40D. Also noise seemed to be better on the 40D but not significantly.
Jeremi
http://www.jeremiblurt​on.com (external link)
JB Photography - Facebook Fan Page (external link)
5D Mark iii, 7D, 24-70 2.8L, 70-200 2.8L IS II, 100 Macro 2.8, Nifty, 100-400 4.5-5.6L and a bunch of other stuff.
mmahoney
Jan 27, 2010 08:32 |  #14
JFusion wrote in post #9481208 (external link)
Misconception about your autofocus performance .. I'll look for the link but a Japanese tester compared the 20, 30, and 40D's with dogs, horses, cars, and joggers and found no difference in keeper rates. If I remember correctly all three camera bodies averaged about 40% sharp photo keeper rates with these subjects. But he had cool filmstrip 100% type files showing the series of drive bursts.
Or try it yourself .. get a friend to run towards you and shoot them with both bodies and compare the keeper rates. And if you get more than 50% acceptably sharp, post 'em up and you'll get a prize.
Canon's marketing and our own upgrade spending justifications often cloud judgement.
ValkyrieLenneth
Jan 27, 2010 08:35 |  #15
Same noise level, bigger resolution. Isn't it an upgrade already ? :lol:
Canon EOS: [40D] [5D]
EF: [24-70 f/2.8L] [70-200 f/4L] [50 f/1.4]
Speedlite: [550EX]
The only easy day was... yesterday. :lol:
5,998 views & 0 likes for this thread, 19 members have posted to it.
1459 guests, 130 members online
