Thread started 27 Jan 2010 (Wednesday) 09:15
580EX on a L-bracket
bufferbure1
Jan 27, 2010 09:15 |  #1
Any one have issue with the Flash AF assist beam when the flash head is on mounted on a L-bracket? Would the AF assist beam still be accurate due to the height change of the flash?
Thanks.
"I collect pictures, not gears..."
Lenscode:1635.1785.50f​18.100Macro.70200F4IS.​580EX.30D.5D2
PacAce
Joined Feb 2003
Jan 27, 2010 09:46 |  #2
You would have to really get the head misaligned for the AF assist beam to miss its mark if you are using the center AF point. But if use the outer AF points quite often, it would behoove you to make sure the flash is pointed where you want it to for the working distance your subject is usually at.
...Leo
jackies35
Jan 27, 2010 09:56 |  #3
Hey, I haven't heard or noticed anything with the 580 EX II & Flash Bracket....
Did you check the threads below??
good luck!
Just a Christian passing by Event Photography.......
www.pictureme2.com (external link) & www.twitter.com/pictur​eme2 (external link)
Nikon D7000 18-105 mm f3.5/50 mm f/1.4
Rebel XT
/50mm f1.4/Sigma 17-70mm f2.8
970 views & 0 likes for this thread, 3 members have posted to it.
961 guests, 138 members online
