Thread started 31 Jan 2010 (Sunday) 11:51
Will the new 70-200 2.8 IS have a more consistent focus across the zoom range?
cfibanez
Jan 31, 2010 11:51 |  #1
My current 70-200 2.8 IS needs -10 focus microadjustment at 70 mm, but +5 at 200mm. So it's essentially one or the other. Not great. I wonder whether Canon has improved focus consistency across the zoom range of this lens in the Mark II version. That would be a pretty good reason for me to upgrade.
2010-06-18: SEE UPDATE BELOW
5D4 | 7D2 | 11-24/4.0 L | 16-35/2.8 L III | 24/1.4 L II | 24-105/4.0 L IS | 40/2.8 STM | 85/1.2 L II | 100/2.8 L macro IS | 70-200/2.8 L IS II | 100-400 L IS II | 400/4.0 DO L II | 580EXII | EF 1.4x III | Gitzo monopod GM2541 | Gitzo tripod GT2541 | Really Right Stuff ball head & plates | B+W & Singh-Ray filters
RWatkins
Jan 31, 2010 12:01 |  #2
...or have the body correlate MA and zoom. This would be a neat feature for Canon to give us.
Stuff and things
President – International Brotherhood of Instagram Haters
ImRaptor
Jan 31, 2010 12:23 |  #3
I think you're likely to see the same thing you do now with the 70-200s: Variation.
One may be perfect, while the next will need +10, while the next will differ throughout the zoom range.
http://imraptor.devian​tart.com/ (external link)
Why yes, I am a jerk. Thank you for asking.
cfibanez
Jan 31, 2010 13:01 |  #4
RWatkins wrote in post #9510885 (external link)
This seems a bit too tricky. I don't see the sensor moving back and forth as you zoom in and out. But stranger things have happened ...
Incidentally, does anyone know whether different MAF settings can be registered under the C1, C2, C3 positions? That would be one possible way out ...
EDIT: I tried this and failed. I could not register a different MAF value in the C positions, even though the manual says —on p. 224— that Custom Functions are registerable.
TheHoff
Don't Hassle....
Jan 31, 2010 13:07 |  #5
The sensor doesn't move in and out for microadjustment; it is a correction to the autofocus values transmitted between the body and the lens. It should be simple for Canon to program it so it is also focal length aware on a zoom.
••Vancouver Wedding Photographer  (external link)••| [gear list] | Latest blog: 5 steps to stopping image loss (external link)
cfibanez
Jan 31, 2010 14:05 |  #6
TheHoff wrote in post #9511245 (external link)
Right, thanks for clarifying this. I wonder whether this could be taken care in a firmware update ...
My lens is still under warranty. Anyone knows if there is some type of calibration that Canon service could do to remedy this?
cfibanez
Feb 20, 2010 05:35 |  #7
My 70-200 is now with Canon for calibration of its (uneven) focus. Will report on this as soon as I get it back. Fingers crossed.
Socrates99
Feb 21, 2010 13:18 |  #8
Did Canon charge you for the calibration or was it under warranty? I am continously tweaking my micro-adjustment on this lens. My 24-70L is spot on but I really struggle with this one and have been wondering if it is in need of calibration.
Gear: Canon 1D MK III | 5D MKII | 300 F/4 L | 24-70L | 24-10L | 70-200L IS 2.9 | Canon 50mm 1.4 | Canon 70-300mm IS f/4.5-5.6 | 580EX II | 430EX
Yaamon
Feb 21, 2010 13:42 as a reply to  @ Socrates99's post |  #9
A proper focusing zoom like the 70-200mm I presume should focus throught the entire focal range properly.
My 70-200 F4 and 24-105 F4 IS does.
I had to send in my 28-135mm, 2 times to correct a focus shift from 70-135mm. Between 28-70 it would focus dead center where I set it and from 70-135 it would slightly drift front focus.
Now after calibration its dead center throught the focal length.
My Tamron 17-50mm had focus issues that up to 5 feet would be fine and then front focus at futher distance. After 2 calibration it was better but at 17mm I noticed that it was dead on and front focus from 24-50mm.
After I spoke to the tech exactly what the problem was he understood and siad that could be fixed. I sent in my 50D with the lens set at 0ma. He was able to correct it that between 17-50 it focus dead center at 0ma.
Im very happy with the performance of the 70-200, but if the new 70-200 F2.8 IS II as they say is better optically plus the stabilizer performance of the F4, I think I might upgrade despite the weight. The weight was what holding me back from buying the 2.8 IS. :(
cfibanez
Feb 21, 2010 15:17 |  #10
Socrates99 wrote in post #9652371 (external link)
It's still under warranty. I haven't picked it up yet, but they took copy of my receipt and gave (so far) no signals that I may be charged. I'll find out soon.
cfibanez
Mar 06, 2010 15:38 |  #11
I am happy to report that the lens came back from Canon with a nice an uniform focus. MAF at -1 makes it perfect from 70 to 200mm. Worth while sending it in!
something-wild
Mar 16, 2010 16:53 |  #12
cfibanez wrote in post #9510823 (external link)
sorry to ask but,how do u know it needs the adjustment and how do u find that out?
Don't think cos I understand,I care.
ChrisMc73
Mar 16, 2010 16:56 |  #13
something-wild wrote in post #9809904 (external link)
I was about to ask the same thing, some of you guys just are so into this stuff!
cfibanez
Mar 19, 2010 17:53 |  #14
You shoot to one of the many targets available for focus tests (I use THIS ONE) at 25 to 50 times the focal length; camera on tripod, remote shutter release, mirror lock-up, etc.. Change MA settings on your camera to cover all the range as much as possible taking shots at different intervals (I do a first series at intervals of 5 units MA, i.e. -20, -15, -10 ... all the way to +20). You look then for the best focus in your monitor at 100% magnification. You figure out which MA settings fits best your lens, This is a rather common problem with zooms. I re-did the test after my lens came back from Canon and I was very impressed. The huge difference that was previously present between the wide and long ends disappeared!
something-wild
Mar 24, 2010 13:05 |  #15
cfibanez wrote in post #9831569 (external link)
3,335 views & 0 likes for this thread, 8 members have posted to it.
1323 guests, 127 members online
