If you could only pick one of these two fine lenses for mostly landscape (including panoramas) and also a bit of architectural work, which one would you choose?
Thunderheart Member 67 posts Joined May 2006 Location: South Australia More info | Feb 01, 2010 02:30 | #1 If you could only pick one of these two fine lenses for mostly landscape (including panoramas) and also a bit of architectural work, which one would you choose? Canon: 5D MkII, 40D, 10D, all gripped | 24-70mm f2.8L | 70-200mm f2.8L IS | 17-40mm f4L | 24-105mm f4L IS | 100-400mm f4.5-5.6L IS | 50mm f1.4 | 100mm f2.8 Macro | 10-22mm f3.5-4.5
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Feb 01, 2010 05:23 | #2 The 17.
Quad Goldmember 1,872 posts Likes: 3 Joined Nov 2005 More info | Some people suggest the 17 and use a 1.4 TC to get to 24.
DrPablo Goldmember 1,568 posts Likes: 3 Joined Jan 2006 Location: North Carolina More info | Feb 01, 2010 10:07 | #5 On full frame I'd get the 24 and on crop I'd get the 17. You're going to get a lot of superwide perspective distortion with the 17mm lens on a full frame camera. If you're shooting superwide landscapes ~ 17mm on full frame, then you're going to have an enormous DOF anyway and won't need tilt, and you'll have a huge angle of view and won't need much shift. Canon 5D Mark IV, 24-105L II, 17 TS-E f/4L, MPE 65, Sigma 50 f/1.4, Sigma 85 f/1.4, 100 f/2.8L, 135 f/2L, 70-200 f/4L, 400 L
Feb 03, 2010 22:58 | #6 Thanks folks. Its certainly been a question on my mind ever since they announced the 17mm. Canon: 5D MkII, 40D, 10D, all gripped | 24-70mm f2.8L | 70-200mm f2.8L IS | 17-40mm f4L | 24-105mm f4L IS | 100-400mm f4.5-5.6L IS | 50mm f1.4 | 100mm f2.8 Macro | 10-22mm f3.5-4.5
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Feb 04, 2010 05:17 | #7 Quad wrote in post #9517200 On the other hand 17 is getting so wide that it is becoming an even more specialized lens in a group of already specialized lenses. This. connecticut wedding photographer
| Latest registered member is ealarcon 720 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
