Thread started 01 Feb 2010 (Monday) 07:49
Soft images with 7D anmd 300/2.8 Combination
rakesh
Feb 01, 2010 07:49 |  #1
Hi
I ma using 7D with my trusted 300/2.8 since November and earlier when the first ware was 1.0.7 on my 7D, ised to get crisp images when I used 300/2.8 with it irrespective of whether I used Bare lens or converter attached to it but now 7D is not giving me similar results after upgrading firmweare to 1.1.0.
Yesterday I shoot almost 150 + images and on the LCD most of the images were looking sharp but after transferring to the system, all images were so soft that even after processing, images are still soft.
Can anyone help me finding the solution to this.
Here are two images directly from the DPP without any processing, just resized.
IMAGE: http://farm5.static.flickr.com/4026/4322382742_57a33bbaa1_o.jpg
IMAGE: http://farm5.static.flickr.com/4033/4321648235_7efa83c144_o.jpg
Gears:
My WildLife Gallery :
http://www.justwildlif​e.com (external link)
My Kids Project Galleries : http://www.facebook.co​m …otography/15851​1907574485 (external link)
stsva
Gallery: 45 photos
Feb 01, 2010 08:22 |  #2
It looks like the lens may be front focusing. I'd suggest doing some test shots under controlled conditions (tripod, good lighting, high contrast target - maybe something like the Lens Align or TeamSpeed's Focus Genie https://photography-on-the.net/forum/showthre​ad.php?t=771158 if available). It could be that for some reason you need to do an autofocus microadjustment.
Some Canon stuff and a little bit of Yongnuo.
http://www.pbase.com/s​tsva/profile (external link)
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
gotak
Feb 01, 2010 08:48 |  #3
Did it reset your "picture style" settings after the firmware update? Check the sharpening settings in DPP and the NR settings as well.
http://bubble-trees.com/ (external link)
7D x2,, 50 f1.8, 11-16 f2.8, 17-55 f2.8, 70-200 f2.8 IS II, 100 2.8L, 430EX, 580EX, Di866, pixel king wireless TTL trigger.
GW2
Feb 01, 2010 08:56 |  #4
I was going to sat front focus, based on shot one, but I can't see it in shot 2. Hmmmm
rakesh
Feb 01, 2010 09:09 |  #5
gotak wrote in post #9516853 (external link)
Gotak,
Yes, it did reset and then I reselected it as Standard and sharpening level is 3 and all shots taken are in RAW.
Gears:
stsva
Gallery: 45 photos
Feb 01, 2010 09:11 |  #6
GW2 wrote in post #9516890 (external link)
I agree, the second shot looks just plain hazy throughout. I don't think the OP will have much success figuring this out without doing some controlled testing.
Member of the GIYF
Club and
HAMSTTR
Image Editing OK
rakesh
Feb 01, 2010 09:12 |  #7
I upgraded the firmware when it was released itself and initally I thought that some setting got changed but when even after taking approx. 400+ shots and almost all are identical i.e. Soft, I suspent it is the problem of firmware and not the lens because I tried all shooting modes One Shot, AI Focus and AI Servo and also all metering options but still the results are same.
Tomorrow I'll perform some tests using Invisicord focus test sheets or with some high contrast material.
Gears:
gabebalazs
Bird Whisperer
Gallery: 52 photos
Feb 01, 2010 09:12 |  #8
yeah, the first shot is definitely front focused, unless you wanted the bird's tail in focus. Parts of that picture look sharp.
how were the weather conditions? Was it hazier than usual? With tele lenses a bunch of extra factors come into play and can influence IQ. I'd say there is a bigger problem with contrast in the second image than sharpness (yeah it could be sharper too, but contrast is missing.)
SONY A7RIII | SONY A7III | SONY RX10 IV | SONY RX100 | 24-70 2.8 GM | 70-200 2.8 GM | 16-35 F/4 | PZ 18-105 F/4 | FE 85 1.8 | FE 28-70 | SIGMA 35 1.4 ART | SIGMA 150-600 C | ROKINON 14 2.8
Gabe Balazs Photo (external link)
Nature Shots Portfolio (external link)
rakesh
Feb 01, 2010 09:16 |  #9
gabebalazs wrote in post #9516970 (external link)
HI
I focussed it on eyes in first image and second as well. The climate was morning golden light conditions when you get maximum / optimal conditions for best images. No clouds nothing. My friend who took images with his 40D and 100-400 are clear and there is no hazyness in his images.
Gears:
f.2.8
Feb 01, 2010 09:19 |  #10
Try to step down a bit, to f 4-8, change focusing to mid point only, check camera settings for sharpness and contrast, factory settings alwasy very soft ( setting around 3... increase sharpness setting to 6-7)
I dont think you are out of focus with your pics, more likely to have wrong settings...
The first pic with the hawk is focused at the back, not the head as it should.
Hope this helps ...
hokki
rakesh
Feb 05, 2010 07:17 |  #11
Hi All
Thanks for going thru the images and suggesting solutions. I also performed testing in controlled environment with camera and lens mounted on Tripod but the results were still same.
Today I took my camera to Canon Service Centre and even they also got surprised to see such results from such an advanced Camera.
They tested my lens with their inhose demo body as well and results were extremely sharp, in focus and proper contrast.
Final result that they came to was the culprit is Body and not the Lens and they have asked me to contact tomorrow and by that time they will perform some Focussing/Sharpness setting.
For your information, I was getting such images since I upgraded the firmware to 1.1.0. Will update once I get back my camera.
Gears:
vicza
Feb 08, 2011 23:04 as a reply to  @ rakesh's post |  #12
Hi folks - I know this is an old thread, but I seem to be experiencing the same problem as described by Rakesh, using the exact same equipment. Does anyone know what the outcome/solution was?
int2str
Feb 08, 2011 23:05 as a reply to  @ vicza's post |  #13
vicza, post some example pictures and 100% crops.
rakesh
Feb 08, 2011 23:18 |  #14
The issue resolved by modifying the custom function and making Zone AF and Manual AF Point selection options enabled.
Gears:
RLJSlick
Gallery: 19 photos
Feb 08, 2011 23:23 |  #15
There you go! I learned the hard way you want to be more selective when you do bird photography, it could make or break your shot.
Ricky L. Jones
Canon 7Dmk II, 5Dmk III, 7D, 50D
About me (external link)
Twitter (external link)
Google+ (external link)
Facebook (external link)
4,806 views & 0 likes for this thread
1171 guests, 286 members online
