Thread started 01 Feb 2010 (Monday) 13:01
Canon 9500 MKII Printer Driver Question
Alex_c70
Feb 01, 2010 13:01 |  #1
I'm getting mixed results with this printer and have noticed a number of folks mention turning off printer driver color management. I want to let Lightroom 2 handle the color management so how do I ensure that the printer driver is turned off, disabled, or whatever the case so that I don't have both the driver and Lightroom trying to manage color?
I simply can not figure this out and would really appreciate any help. :oops: :D
tonylong
...winded
Gallery: 60 photos
Feb 01, 2010 15:36 |  #2
Alex, at the bottom of the Print module there are settings for the print job, one of which is color management. If you open the drop-down list there, you should see profiles for your printer with various paper types. If you are using Canon paper, it should show up there. If you are not using Canon paper and you don't have a profile for the paper you are using, then you won't have reliable results.
Then, to turn off color management by the printer, you will open up the printer settings, using the driver which you access once you begin the printing process (or in the Properties of the installed driver). Your initial Print dialog would have a Preferences option which you would choose, and from there one of your options would be for color management. You will select from a list of options to have the application manage your color (or words to that effect -- I don't own your printer).
It's important that you complete both of these steps so that you don't have your prints "double-processed".
You should also know that having your monitor calibrated is part of the process for reliable results. This includes lowering the typical brightness of your monitor as well as getting a reasonable color balance that will translate well to print as well as to sharing across the Web, etc.
Tony
Alex_c70
Feb 01, 2010 17:14 |  #3
tonylong wrote in post #9519486 (external link)
Thanks Tony! I'll give this a try. I should have also mentioned that I have a MacBook Pro, running OSX 10.5.8. I'm not certain if this matters and apologize if it does; I should have included that info before.
tonylong
...winded
Gallery: 60 photos
Feb 01, 2010 17:16 |  #4
Alex_c70 wrote in post #9520210 (external link)
Yeah, different OSs and different printers/drivers. Someone with a Mac and a Canon could chip in here:), but the fundamental steps should be the same.
Tony
Car2n
Feb 01, 2010 19:18 as a reply to  @ tonylong's post |  #5
In your printer perferences,
Go to the Color/Intensity section and select "Manual".
Then click on the "Set" button."
Another box will open - Manual Color Adjustment
Click on the "Matching" tab and select "None" in the Color Correction section.
Canon 1D3 / 70-200mm f/2.8L IS / 17-40mm 4.0L / 50mm 1.4 / 580EXII / Manfrotto 055XPROB/488RC2 / PixmaPro 9000ii / StylusPro 3800
Alex_c70
Feb 02, 2010 10:27 as a reply to  @ Car2n's post |  #6
I'm still having a terrible time figuring this out. In Lightroom, in the Print module under Color Management, I've selected the icc profile for the Ilford paper I'll be using. When I click Print, I see the dialog box in the first image.
It seems like Color Matching would be the appropriate choice; I select this and see what is in the second image. ColorSync and Vendor Matching are the only choices and aren't available. Does this mean that Lightroom is overriding the printer driver and using the Ilford icc profile? Oh please let this be the case. :lol:
René ­ Damkot
Feb 02, 2010 10:56 |  #7
LR2 is setting the printer driver for you. This is correct & expected behaviour.
http://luminous-landscape.com …96&view=findpos​t&p=240778 (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Alex_c70
Feb 02, 2010 12:14 |  #8
René Damkot wrote in post #9525076 (external link)
Thank you, René! The poster mentions that:
"Only two print paths are supported under Leopard, and this requires all parties involved (application, OS, driver) to be working in concert for both print paths to work correctly."
So does this mean that when I choose the Ilford icc profile, that Lightroom, OS, and driver are "working in concert"? When you mention that LR2 is setting the printer driver for me, does this mean that LR2 uses the Canon driver while also using the icc profile to properly map colors?
René ­ Damkot
Feb 02, 2010 12:31 |  #9
Disclaimer: I never print from LR2, I use PSCS2.
As far as I know, in OSX 10.5 and later, if you set LR (or PS) to manage colors, this will result in the printer driver being set like the screenshot you posted.
I never got it to work correctly in PSCS4 / OSX 10.4.11, but that is a different issue AFAIK.
Alex_c70
Feb 02, 2010 15:40 |  #10
René Damkot wrote in post #9525638 (external link)
Thanks again. I've now run some test prints and it's interesting that the colors are off using the Ilford icc profile, but nearly perfect when I select Managed by Printer.
René ­ Damkot
Feb 03, 2010 06:48 |  #11
Hmmm.
Might try a few of the suggestions here (external link).
Natural ­ Imagez
Feb 03, 2010 09:16 |  #12
Alex_c70 wrote in post #9526923 (external link)
i been strugglin with the same things with my pro 9000 mkII. i did some tests on a print last night, letting photoshop manage colors, printing from proof view, not printing from proof view, everything i could think of. all came out with a noticiable red tone on the skin tones, except for when i let theprinter do color management. it was dead on.
Canon 1DMKIII
24-70 L *Speedlite's 580 ex II x2 *cybersync radio triggers x4 * AB800's x2
Mike Kasper
www.naturalimagez.com (external link)
sdipirro
Feb 03, 2010 11:44 |  #13
Well, I'm also using Ilford paper and ICC profiles with my Pixma Pro 9500 with CS4 on Windows XP. My monitor is calibrated with Spyder3Elite. I let Photoshop manage colors, and the picture on the screen pretty much exactly matches what I get in print. I've had good success using the EasyPhotoPrint Pro plugin for CS4 that came with the 9500 too.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
4,299 views & 0 likes for this thread, 6 members have posted to it.
1043 guests, 116 members online
