Thread started 02 Feb 2010 (Tuesday) 02:13
Way To Determine 20D Shutter Count
tfd888
Feb 02, 2010 02:13 |  #1
I know this has been brought up before about trying to figure out the shutter count on 20D bodies and nothing really conclusive has been found but I had an idea which I haven't seen mentioned. Doesn't the 20D create a new folder after every 100 files and increment the folder no. by 1? Couldn't you get an estimated shutter count based on what your folder no. is? Or am I just really short on sleep :lol:
Alexander R.O.
1D-Mark III ~1D-Mark II ~ 60D ~ 20D (Gripped)
(70-200mm L 2.8 IS) ~ (17-40mm L 4.0) (Sigma 24-70mm 2.8 EX DG Macro RIP) ~ (50mm 1.8 MKII) ~ (Alpex 35mm f/2.8 M42 mount) ~ (430EX II) ~ (Yongnuo YN-560 III)
My Website (external link) - My Blog (external link)
- My Flickr (external link)
S30L28
Joined Sep 2009
Feb 02, 2010 02:31 |  #2
http://www.flickr.com …iscuss/72157594​389608272/ (external link)
I went here and I found the count on my old 20D. Not as easy as the newer xxD models, but works!
Also, I would not base the shutter count by the file numbering system. Those can be changed depending on the numbering on the card you use.
Hope that helps!
-Brian
Equipement d'appareil photo
Seller Feedback:1 (external link), 2 (external link), 3 (external link), 4 (external link), 5 (external link)
tfd888
Feb 02, 2010 03:15 |  #3
S30L28 wrote in post #9523234 (external link)
Hope that helps!
Well, based off of the hex method I have around 30k on the shutter which seems about right. I checked multiple files and it seemed to be accurate across the multiple files I checked.
Thanks for the link :D
Alexander R.O.
DStanic
Feb 02, 2010 06:39 |  #4
I ran the test with the hex decoder, and it said my 20d has 15,xxx .. I'm sure it is much more then that. Would canon reset it after replacing a shutter? (previous owner had it replaced)
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
msowsun
"approx 8mm"
Gallery: 18 photos
Feb 02, 2010 07:44 |  #5
Hope that helps!
It does not work. Scroll down and read this.... http://www.flickr.com …iscuss/72157594​389608272/ (external link)
In Plain English: It Doesn't Work :)
Really, people have been trying to figure out how to get an accurate shutter count for the 20D and 30D for a long time and nobody has found a way to do it other than to use Canon's special software. Why this information is hidden from us on these cameras is a mystery.
If you want to prove that this method does not work, do the following:
First, take a photo using the CF card you've got in the camera now.
Remove that CF card and set it aside. You'll need it later to restore your file numbering to where it is now.
Take a different CF card and using a card reader connected to your PC, delete all files and directories on the card.
Now, insert that card into your camera.
In the Menu, find "File Numbering". Switch that from Continuous to "Auto Reset".
Now, take a photo.
Remove that CF card and put it back into your card reader connected to your PC.
Open that RAW file with the hex editor.
The actual file number is Folder 100, shot 0001 but the decoded Hex will tell you that the number is now 281.
This tells us that first, this location does not show the actual shutter actuations and second, this number cannot be simply decoded as a standard HEX number to even read the file number.
A while back, someone posted the way to properly decode this data to arrive at the current file number on the DPReview 20D forum. I don't remember the details but the main point is that this pair of locations does not give the number of shutter actuations. It only gives you the current file number, and that is easily reset so you never can know what the true shutter count is for a 20D.
Ok, now if you want to get your camera set back to the same shot number as where you left off (more or less), do the following:
Put the card with the 100 0001 shot on it (The shot you just took) back into the camera. Go into the menu and set the File Numbering mode back to "continuous".
Now remove that card.
Install the card we set aside earlier.
Now your camera's numbering will adopt the numbering from that old card and you should be back where you started.
Sadly, nobody that I know of has cracked this mystery...... yet :)
Jim
Posted 38 months ago.
jack ­ lumber
Feb 02, 2010 09:09 |  #6
Try this,
Load an unedited shot to Flickr, go to "more properties" and look for "shutter count".
There is a fine line between "hobby" and "obsession"
5D-20D-7D gripped- all canon-28MM 1.8 - 50MM 1.8 -17-40 L -100MM 2.8 macro -70-200MM L F4- 100-40MM L -1X4 teleconverter-Sigma 20-40MM 2.8:D 580 EX 11 flash- manfrotto tripods and monopods.
tfd888
Feb 02, 2010 12:48 |  #7
I'll look into the Flickr method but I had heard that it isn't accurate either.
The mystery continues :lol:
Alexander R.O.
6,730 views & 0 likes for this thread, 5 members have posted to it.
1373 guests, 193 members online
