CameraBuff wrote in post #9535194
OK, I read all the posts I could find here on POTN and I will clean my sensor on my 40D next weekend. I have a large rocket blower, the sensor brush, sensor tool, eclipse and pec pads from Copperhill and the Sensorklear. I was going to use the blower 1st, than brush, than Sensorklear - check than wet clean if needed; however, now I am seeing posts saying not to use the rocket blower or you could blow dust up into the viewfinder?
What steps are you using!
CameraBuff,
Just as the brochure describes, it's very important to wet-clean your sensor before using any dry tool. You don't have to expect great results as far as removing dust-bunnies, what you're doing is getting rid of the film of chamber lube. If you do see what looks like a fairly big stuck-on speck, this is the only case where it is advisable to use a pen or brush to dislodge it, if the brush picks up lube, it's very easy to clean it thoroughly.
I believe the D-SLR community is very much for blowing off the sensor as the first step, no discussion neded. A Rocket blower probably won't stir up the air with currents that bring the dust up to the prism area, but a more powerful blower might.
The video that was posted is pretty good for the most part. However, he does need to remove the E2 from his fluid choices and go with Eclipse for all sensors. But look at his swabbing technique at the end. He was most likely looking through his video recorder when he swabbed, so we'll give the guy a break, but his swab is all over the place on the second swipe going left-to-right. What this should tell you is that using a full-frame swab to cover the entire height of the sensor means you have to be very precise and wary of going up on the sidewalls. This may make strands of material come loose and it also may drag the lubricant onto the surface. We generally recommend using a smaller swab like an 18 mm. for people who have never cleaned their sensors. The full-frame swabs can be used by someone with a good amount of experience.
Nicholas
