Thread started 03 Feb 2010 (Wednesday) 22:25
New computer...dark prints??
mike397
Feb 03, 2010 22:25 |  #1
I,ve upgraded to a new dell,64bit,windows7 machine.
Problem is, after I calibrated my monitor{nec},my prints are coming out dark.
I have an epson1800 printer,and use Lightroom for my editing ,them send the tiff files, to qimage for printing.
I,ve run nozzle checks,and the printer seems to be working fine.
I am using a 2 year old, spyder2 express calibration device.
Up till now,my prints matched my monitor almost exactly.
Is it time for a new calibration device?
Do these things wear out or become obsolete over time?
If so,which one do you recommend
I,ve been looking at the spyder3,and the color munki
Also,I,ve read some where that the tank on, the epson printers should be emptied ,that this could possibly be a cause of the problem????
Any help/suggestions, would be greatly appreciated
Mike
Canon 24-105L ,,Voigtlander 40mm & Apo Lanthar 90mm macro...,Nikon 55mm f2.8 micro ,Leica 60mm f2.8 macro ,Leica 180mm f4, Zeiss c/y 135mm f2.8 ,Olympus 21mm f3.5
http://mike397x.zenfol​io.com/ (external link)
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 03, 2010 22:41 |  #2
Are you using the latest software version (64 bit support)?
http://support.datacol​or.com …sion&_m=downloa​ds&_a=view (external link)
Also can you (barely) distinguish between the two left-most black boxes on the grey scale chart on this page? http://www.displaycali​bration.com/ (external link)
Bob
mike397
Feb 03, 2010 22:55 as a reply to  @ Bob_A's post |  #3
Bob,Thanks for your reply
Yes,I updated to the new 64bit driver.
Let me throw this at you,if I may
I,m having Lightroom edit the raw files in prophoto rgb....then I bring the edited image to Qimage ,as a 16 bit tiff.
Should I use Srgb instead
Will,this make any difference??
Looks like I,m grasping at straws,here.
I'm really bugged with this problem,my printer is basically dead in the water..
Mike
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 03, 2010 23:10 |  #4
Can't you convert to sRGB and print directly from Lightroom? Also, when you soft proof how does the image look?
Hopefully Rene or one of the other color management gurus will step into your thread to help.
Bob
mcluckie
I play with fire, run with scissors and skate on thin ice all at once!
Gallery: 109 photos
Feb 04, 2010 00:21 |  #5
Its in your print settings. Check and experiment with letting ps color manage, or the printer. I guarantee it in there.
Tristimulus colorimeters don't wear out. Software kills them.
multidisciplinary visual guy, professor of visual art, irresponsible and salty.
Leicas, Canons, Hasselblads
all and historic dingus
René ­ Damkot
Feb 04, 2010 06:23 |  #6
mike397 wrote in post #9536782 (external link)
Different machine or just different OS?
Different monitor as well?
Calibration went well? (No error messages, 'old' images still look the same, etc)
You have the latest (64 bit) versions of Qimage and printer drivers?
Everything else (settings etc) identical to your old system?
Have you tried running in 32bit mode (is that possible in Win7?)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
ChasP505
"brain damaged old guy"
Feb 04, 2010 07:01 |  #7
Does your NEC monitor support the NEC Spectraview system?
Chas P
mike397
Feb 04, 2010 07:24 as a reply to  @ ChasP505's post |  #8
Rene,thanks for your reply.
Yes,a new machine,and a new OS{now windows 7}
Same monitor.
Calibration went smoothly-no error messages.
Old images ,seem to look a little brighter,
64 bit upgrade drivers for all.
Everything else is exactly the same
Not sure about 32 bit mode,I will look into this.
Please keep in mind,the differences are not severe,but I can see the difference.
I'm using the epson printer profile for the Luster paper,and a custom profile that Eric Chan made for the Museo silver rag paper{my paper of choice}
Chas,,not sure about the spectra view software,but I'll check into this.
Thanks again guys
Mike
mike397
Feb 04, 2010 07:36 as a reply to  @ mike397's post |  #9
Bob A
Yes,I can export to a jpeg,and also if i choose,print directly from Lightroom...but,
I really like the job Qimage does,it's a great program
Your idea,is a good one,I will try to print directly from Light room ,to see what the result might be..
I'll get back to you on this..Thanks
Mike
tonylong
...winded
Gallery: 60 photos
Feb 04, 2010 09:17 |  #10
Mike, if your prints are dark and older images look bright it just sounds like your monitor brightness needs to be notched down. Sometimes a calibration run will get it just right, sometimes not -- it depends on the monitor, the ambient light, and how the software/hardware does the job.
Tony
mike397
Feb 04, 2010 18:41 as a reply to  @ tonylong's post |  #11
Tony
Thanks for your reply.
Here are my settings ,after calibration:
Brightness=30.4%
Contrast=50%
Sharpness=16.6%
These are the same numbers I had,before I got the new computer ,when I was running windows XP..
Do you think,I might need a new calibrator,say,Spyder3 or color munki??
Mike
tonylong
...winded
Gallery: 60 photos
Feb 04, 2010 20:11 |  #12
Mike, I'd try notching your brightness down until the display looks bad, then notch it up just until it looks "acceptable" -- it will tend to look dimmer than you are used to, but it's at least a start. Run a test print and see how it compares and take it from there.
Adjusting monitor brightness can be hit-or-miss, depending on the monitor, and calibration software handles it in different ways, and maybe running the fresh calibration on the new OS just didn't "catch" the proper levels?
Tony
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 04, 2010 23:43 |  #13
I know when I print to Smugmug's EZPrints I need to soft proof using EZPrints printer profile and do a curves adjustment to get the soft proof rendition to match what I want.
When you print to your own printer don't you still need to soft proof?
Bob
mike397
Feb 05, 2010 03:58 as a reply to  @ Bob_A's post |  #14
Tony--I'll try what you suggest,and post back ,hopefully this will work?
Bob--To be honest,I rarely soft proof,the results I was getting ,prior to my new computer, were more than acceptable.
Edited in Lightroom,sent the resulting image to Qimage ,and that's it.
My results were perfect,especially using the silver rag paper,with Eric Chan's profile
Thanks again guys,
Mike
ChasP505
Feb 05, 2010 06:59 |  #15
mike397 wrote in post #9538537 (external link)
...Chas,,not sure about the spectra view software,but I'll check into this.
Hmmmm... If you don't know, then most likely it doesn't support Spectraview. I was just thinking that maybe you could use your Spyder2 with the NEC's own calibration software and eliminate the calibration as a factor.
Chas P
6,473 views & 0 likes for this thread, 12 members have posted to it.
1369 guests, 182 members online
