I have just ordered my Canon 420EX flash. Can I attatch to it an optical hot shoe slave so that I can use off camera triggered by the built-in camera flash? Will it damage the flash?
sito Senior Member 419 posts Joined Jun 2005 Location: USA More info | Jun 28, 2005 04:51 | #1 I have just ordered my Canon 420EX flash. Can I attatch to it an optical hot shoe slave so that I can use off camera triggered by the built-in camera flash? Will it damage the flash? 20D - 10-22mm - 17-85mm - 50 f/1.4 - 70-200 f/2.8L IS - 100mm Macro - 1.4x II - 420EX - Canon 550EX
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jun 28, 2005 05:06 | #2 You'd have to find a hot shoe unit that's designed for Canon, to flash the 420EX when it senses another flash go off. I've not heard of one, but i'd be kinda interested if anyone else has. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
I phoned Canon tech support and I was told that it was Ok to use a hot shoe slave with the flash. I will use it and will tell what happened. 20D - 10-22mm - 17-85mm - 50 f/1.4 - 70-200 f/2.8L IS - 100mm Macro - 1.4x II - 420EX - Canon 550EX
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | sito wrote: I phoned Canon tech support and I was told that it was Ok to use a hot shoe slave with the flash. I will use it and will tell what happened. When they said it was OK, they meant that it was not going to burn up the equipment. The degree of compatibility will vary depending on several things. A "regular" hot shoe slave trigger that fits onto the "foot" of the flash unit will trigger on the first flash pop from the main flash, but that is the pre-flash pop, not the main pop. There are special hot shoe slave triggers that will see the first pop, then wait, then go on the second pop.
Where can I get one of these? 20D - 10-22mm - 17-85mm - 50 f/1.4 - 70-200 f/2.8L IS - 100mm Macro - 1.4x II - 420EX - Canon 550EX
| Latest registered member is IoDaLi Photography 1278 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
