I recently bought a new 17-40mm L and have noticed that the front element physically contacts the filter (tiffen UV) when the lens is zoomed to 40mm. Is this an issue with the lens itself, or would a slimline filter fix the problem?
-James
biggusdickus Member 38 posts Joined Feb 2010 More info | Feb 05, 2010 10:56 | #1 I recently bought a new 17-40mm L and have noticed that the front element physically contacts the filter (tiffen UV) when the lens is zoomed to 40mm. Is this an issue with the lens itself, or would a slimline filter fix the problem?
snatiep Senior Member ![]() 540 posts Joined Jan 2007 Location: St. Paul, Minnesota More info | Feb 05, 2010 11:43 | #2 Hi James, Nate
LBI Member 127 posts Joined Oct 2009 Location: Honolulu, HI More info | Feb 05, 2010 13:26 | #3 Maybe try another filter. 5D | 7D | 50 1.4 | 24-105L | 70-200 2.8L | 580EX
vincent_su Senior Member ![]() 843 posts Likes: 4 Joined Jul 2008 Location: Denver, Colorado; USA More info | This issue has been brought up. Search the thread and you will find the answer. Vincent
y 1600 |
Log in Not a member yet?
Latest registered member is rickldewitt 1212 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 |
