Thread started 06 Feb 2010 (Saturday) 10:29
Sigma 120-300 QR plate recommendation?
PrimeGlass
Feb 06, 2010 10:29 |  #1
Is there a recommended QR plate for the Sigma 120-300 (newer collar version)? If not, what does everyone use to secure a QR plate to it eliminating rotation of the lens on plate? (I'm using a Gitzo head)
5D MKII I 1D MKIII GEAR LIST & FEEDBACK
bobbyz
Feb 06, 2010 10:59 |  #2
I just used regular wimberley/rrs kind of plate that I had for my 70-200mm f2.8. It wasa bit short but worked fine for use on monopod.
Fuji XT-1, 18-55mm
RPCrowe
Joined Nov 2005
Feb 06, 2010 11:07 |  #3
If I understand you correctly, you are asking what type of a plate will prevent the rotation of the foot of the tripod ring around the tripod screw.
I have not had a problem with rotation of any of my three lenses which have tripod rings (70-200mm f/4L IS, 300mm f/4L IS and 400mm f/5.6L).
I attach these lenses to standard plates made by RRS and by Giottos (I use a Giottos MH-657 QR System).
I use a RRS L-Plate when attaching a non-tripod ring equipped camera/lens to the QR clamp. This prevents the torque of the camera around the tripod screw.
However, KIRK markets an Arca Compatible lens plate for the 120-300mm f/2.8 Sigma. This incorporates a flange which is designed to prevent the lens from rotating around the attaching screw.
see: www.kirkphoto.com/Lens​_plate_for_120-300mm_f2.8_EX-hsm_html (external link)
If you don't use an Arca Compatible quick release system on your Gitzo head, you should. Kirk has a conversion system which you could use: http://www.kirkphoto.c​om …Quick-Release-Clamps.html (external link)
PrimeGlass
Feb 06, 2010 11:16 |  #4
Thanks for the info. From the look of the Kirk plate it seems to be designed for the first version of the 120-300 handle. I'll shoot them an email to verify.
New version
HTTP response: NOT FOUND | MIME changed to 'binary/octet-stream'
Old version handle (smaller)
HTTP response: 403 | MIME changed to 'application/xml'
3,057 views & 0 likes for this thread, 3 members have posted to it.
1037 guests, 109 members online
