took three shots today and used trial version of photomatix:
tonyniev Cream of the Crop More info | Feb 07, 2010 14:54 | #1 took three shots today and used trial version of photomatix: Cheers,
GaryMcDuffie Goldmember 3,022 posts Likes: 1 Joined Oct 2008 Location: Scottsbluff, NE USA More info | Feb 07, 2010 14:55 | #2 I'm just not seeing any high dynamic range here. Maybe if you post the origional? Gary
Feb 07, 2010 15:15 | #3 Gary thanks for looking, here are the three originals AV @7.1 TV are .5, .6 and 1/4
Cheers,
GaryMcDuffie Goldmember 3,022 posts Likes: 1 Joined Oct 2008 Location: Scottsbluff, NE USA More info | Feb 07, 2010 15:29 | #4 I still don't see need for HDR processing in these. What is your goal? Is it HDR, or more like special effects? Not trying to be cruel, I just want to understand your goal. Gary
Feb 07, 2010 15:32 | #5 I just wanted to try the photomatix software and I combined these three shots with three different shutter speed. Cheers,
GaryMcDuffie Goldmember 3,022 posts Likes: 1 Joined Oct 2008 Location: Scottsbluff, NE USA More info | Feb 07, 2010 15:56 | #6 Well, for a real HDR shot, you probably should have chosen a different subject that truly has higher dynamic range. You can also do similar to what you have done and go for a more sfx look. More playing with the sliders in these images (in PM) might get you something a little more dramatic. Actually, it looks like you could probably improve the one you have by using PS or LR to increase the contrast. Gary
Feb 07, 2010 18:01 | #7 Yup thanks Gary, I like your occultation avatar Cheers,
GaryMcDuffie Goldmember 3,022 posts Likes: 1 Joined Oct 2008 Location: Scottsbluff, NE USA More info | Feb 07, 2010 22:12 | #8 tonyniev wrote in post #9562208 Yup thanks Gary, I like your occultation avatar Thanks. It's just a flare added in PS. I recently noticed someone else is using the same moon shot without the flare. I may need to change mine to something a little more uniqe. Gary
JoePhotoOnline Senior Member 915 posts Likes: 1 Joined Aug 2009 Location: Central Valley, California More info | Feb 08, 2010 02:33 | #9 One thing about HDR to remember is that it is a tool for capturing images in which one exposure could not cover the tonal range. Typically, indoor shots where the light source (I'm assuming a window in this one) is not in the frame, it's totally unnecessary to use HDR.
| Latest registered member is semonsters 1632 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
