I'm running in to a sync problem when I use both my Cactus V4s and my wireless shutter release. I have 2 different "brands" of wireless shutter releases, JueYing and another cheap $15 EBay Chinese random brand setup. Both releases have 16 channels. Flashes are Quantaray PZ-1 DSZ and the camera is an XS.
The problem I run in to is that when I use both the V4s and the shutter releases I get a late firing flash....most of the time. Sometimes I get a full frame but most of the time I have to step down from 1/200 to 1/50 before I can get a clean shot.
Configurations I tested today are:
No flash, wireless release - WORKING
Flash on camera hot shoe, 1/200, wireless release - WORKING
Flash off camera with V4, 1/200, 2 and 10 sec timer and manual fired shutter - ALL WORKING
Pretty safe to say there's interference with the release and the V4s. It's just curious to me that adding the wireless release to the mix just slows things down and will work with a 1/50 or slower shutter speed.
Anyone else run in to this? Known issue with an easy workaround? Or should I just write it off to cheap equipment. It's not a big deal since I rarely expect to see a situation that I will use both wireless setups.
