Thread started 08 Feb 2010 (Monday) 09:58
Remote flash triggers
Soulful
Gallery: 6 photos
Feb 08, 2010 09:58 |  #1
I own a Canon ID Mark II, Canon 550Ex & JBL Mobilight 300. I have been trying out Rembrandt lighting etc & using the 550Ex as a master on camera to fire the JBL 300, I have the master turned off but it still fires a pre flash that sets off the strobe so my pics are dark. I was thinking of trying out the Blazzeo PT04RF wireless flash trigger that some one had mentioned on this forum. ttp://www.dealextreme.com/de​tails.dx/sku.6201 (external link)
I know nothing about these wireless flash triggers. Can someone tell me, if I order this - is that all I need or do I need to order something else with it?
Hazel
Canon EOS 5D | Canon EF 70-200mm f/2.8L IS II USM EF 50mm f/1.8 EF 300mm f/4L USM EF 100mm f/2.8 Macro USM | Canon Speedlite 550EX
TMR ­ Design
Joined Feb 2006
Feb 08, 2010 10:02 |  #2
Hi Hazel,
If you want to have a Canon Speedlight triggering other non-ETTL strobes then you need to have the Speedlight in manual mode. It won't fire the pre-flash and the flash will be able to optically trigger any studio strobe or hot shoe flash with an optical slave trigger.
Robert
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Feb 08, 2010 10:05 |  #3
The link didnt work for me, but if you are getting the trigger and receiver in the kit you should be fine. You may need a sync cord to connect the receiver to your monolight. I dont know whether you've ordered from dealextreme before but twice its taken me over a month to get my merchandise. It might be good to consider another vender.
Soulful
Gallery: 6 photos
Feb 08, 2010 10:20 as a reply to  @ gonzogolf's post |  #4
Hi, thanks so much for the quick replies. I will give my 550EX another go in manual as suggested. Many thanks.
I love this site - always help whenever needed!
Hazel:D
sethultimate
Feb 09, 2010 12:51 |  #5
Soulful wrote in post #9565967 (external link)
Hazel
you mean JTL ?
I use the cheap radio triggers made by yongnuo (have RF-602) on ebay. They are cheap but work like a charm. very consistent.
on the 1D Mark II you should be able to sync up to 1/250 (I trigger to 1/200 on 1DsII to play "safe").
all you need is the transmitter on the camera and the receiver on 1 strobe. The other strobes will trigger with their own optical slave.
the RF-602 are radio triggers, which means that the signal can even go through walls (unlike the IR that will need to "see" eachother)
the have RF-602 go for 29 bucks shipped , plus 19 bucks for any extra receiver (you use the extra receivers if you want to go via radio for all the strobes, to prevent other flashes to trigger the optical slaves for example
The other way will be to use your flash and trigger the optical slaves with it. It must be set in manual, bounced 90 degrees .
but with the cost of the radio triggers why bother?
Soulful
Gallery: 6 photos
Feb 10, 2010 18:23 |  #6
Hi Sethultimate, your information is very very helpful. I'm really having a hard time with the set up now as is: using the 550ex as master on/off & JTL Strobe as slave, it's very hit & miss with more misses. I know it's me - not doing something right. I've tried different settings but I'm not getting the hang of the AB ratios I think. With the 550EX master flash off - & JTL as slave - my pic is dark. (both camera & 550EX in manual). I don't know what else to do but buy a trigger maybe!
Thank you, Hazel
Soulful
Gallery: 6 photos
Feb 10, 2010 18:25 |  #7
Sethultimate , I'm just now starting to try flash on a more advanced level but still know very little. What did you mean when you stated on the 1D Mark II you should be able to sync up to 1/250 (I trigger to 1/200 on 1DsII to play "safe").
Hazel
gonzogolf
Gallery: 561 photos
Feb 11, 2010 09:33 |  #8
Soulful wrote in post #9584540 (external link)
Hazel
Different bodies have different maxiumum sync speeds. Some inexpensive radio triggers cannot sync as fast as the camera because of the delay in processing the signals so rather than risk getting a black bar across the image because of trigger delay users just pick a slightly slower speed at their max. By safe he means conservative, there is no risk to gear or person involved.
MT ­ Stringer
Feb 11, 2010 10:00 |  #9
Buy a set of those RF-602's. You can get a transmitter and a couple of receivers for about $60 or thereabouts. That way you can get your 550 off the camera and have two off camera lights.
Other trigger options include the CST/CSRB Cybersync's from Paul C Buff which a re a little more expensive. Then EL Skyports are a little more, and eventually, Pocket Wizards. All are very reliable.
I had a set of those triggers you linked to a few years ago and they wouldn't fire more than 6 out of ten times consecutively. Getting rid of them was the best thing I ever did.
Note: If your triggers don't have a hot shoe, you will need a hot shoe adapter (external link) like the one Flashzebra sells for the 550.
Good luck.
Mike
MaxPreps Profile (external link)
My Gear List
primnumbers
Feb 11, 2010 10:05 |  #10
sethultimate wrote in post #9574956 (external link)
you mean JTL ?
Not to take away fome the org post, but how long haveyou had these, and how often do they misfire, and how far away can you be from them
Eugene Nowaczyk
Canon 40D with grip
18-55mm, 28-135mm, 50mm f1.4, 85 f1.8, 70-200mm f2.8
Sigma 50-500
430EX , 540ez (x2) TwinLink wrieless triger
primnumbers
Feb 11, 2010 10:07 |  #11
The best off camera flash triger out there is the "pocket wizard"
Eugene Nowaczyk
Canon 40D with grip
Sigma 50-500
MT ­ Stringer
Feb 11, 2010 10:08 |  #12
primnumbers wrote in post #9588467 (external link)
There is a thread about the rf-602's with many pages of posts. Do a quick search and you should find it.
My Gear List
dsvilko
Feb 11, 2010 10:38 as a reply to  @ MT Stringer's post |  #13
I was probably the one you saw suggesting Blazzeo triggers as a surprisingly reliable low-cost alternative to a more expensive triggers but as they are quite limited in the connectivity options (without DIY modifications) you are probably better of going with the rf-602's. Don't have any experience with them myself but I believe they are considered the ultimate low-cost rf triggers.
1000d | 18-55 | 50mm 1.8 | 55-250mm | reversed 50mm f2.8 Zeiss + 50mm f2.8 as additional macro lens, $10 macro tubes | DIY robotic macro rail (external link) | YN-460, YN-460II | Blazzeo PT-04 triggers
https://photography-on-the.net/forum/showthre​ad.php?t=731733
Soulful
Gallery: 6 photos
Feb 11, 2010 14:20 |  #14
Thanks everyone for all the help & information. Played with settings again today but I'm giving up (for now). Now I'm trying to choose between the Cactus V4s or RF-602 to see which is the better buy! Will scan the posts. Many thanks!
sethultimate
Feb 11, 2010 15:23 |  #15
they are great, honestly.
they don't misfire.
I have them for 4 months and I shoot catalogs on location (600-800 shots per session) . Never a problem.
of course the best are the PW but .. ya know ...
max sync on 1DsII : PW 1/200 , RF-602 1/200 tested and tested again.
the PW is big on my camera with that antenna erected and embarrassing , the RF-602 is small and light.
2 PW will cost a lot of money
2 RF-602 will cost 28.99
the PW will work for longer distances and that's about it. The RF-602 will cover 100-150 ft tops
now the real question is: why the PW are so expensive? is there any "politics" or "fashion" involved?
which is fine with me (fashion is important)
as long as we all understand eachother...
5,677 views & 0 likes for this thread, 12 members have posted to it.
1032 guests, 112 members online
