Thread started 08 Feb 2010 (Monday) 20:38
Canon 500D / 250D Close-up lens question
MizzouMan_2000
Feb 08, 2010 20:38 |  #1
Hello all,
I'm considering buying a close-up filter as an 'intro' to macro photography before dumping a lot of money on an actual macro lens...
So, what I'd like to do is buy one size filter that I can use on a couple of lenses with different filter diameters. So, I thought about getting a 77mm filter and a step-up/down ring. My question though, is if the step up/down ring might throw off the focus or magnification of the lens/filter combination?
Thanks!
http://cisp.zenfolio.c​om (external link)
LordV
Feb 09, 2010 00:51 |  #2
Should work fine like that.
Think you can only get a 500D in that size. Max magnification would be about 0.6:1 with the 70-300mm at the 300mm setting. (mag = lens focal length/500).
You may find it better to think about a set of Kenko ext tubes.
Brian V.
Macro Hints and tips
themadman
Feb 09, 2010 01:53 |  #3
Ya, I think extension tubes are a better investment. They will prove to be useful even later on (even for non macro applications)
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
MizzouMan_2000
Feb 09, 2010 06:20 |  #4
Thanks, Brian & Will. I was actually looking into those after I posted this. The other advantage is if I buy the 3 tube kenko set, the wife & I can share. :)
3,213 views & 0 likes for this thread, 3 members have posted to it.
1472 guests, 134 members online
