Thread started 09 Feb 2010 (Tuesday) 09:23
Sitting camera down on table
eaglefan
Feb 09, 2010 09:23 |  #1
This may be a dumb question. I just received my 17-55 lens yesterday, and now when I sit my camera down on the table, the weight of the lens tips it over so that it is resting on the bottom of the lens. Will this damage the lens? See the attached photo.
As a side note, I purchased this lens used from Adorama and it was rated as "E" quality, which had a possibility of dust. There is indeed some dust inside that I can see, but it hasn't affected image quality that I can tell. There is a local camera shop named Deville Camera that I may call and see if they provide a cleaning service to get the dust out.
5D Mark IV (2) l RP l 70-200mm f/2.8L IS II l Canon 24-105 l Canon 85L 1.4
MattTorresPhoto.com (external link)
krb
Feb 09, 2010 09:25 |  #2
No, it won't damage the lens.
Having said that, with the grip on the body I find it more convenient to lay it on the side so that I can just put my hand on top and pick it up, which also happens to place the lens at less of an angle it that makes you feel better about it.
-- Ken
Gear list
montanawild
Feb 09, 2010 09:26 |  #3
Resting it like that will not hurt anything. As for the dust, if it is not affecting your ophotos forget about it. If you have it cleaned, it will have dust in it in a week anyways.
edit~ krb was typing at the same time......
1DmkIV, 5DmkII, 40Dw/grip
gear list:
http://dehaanphotograp​hy.net (external link)
eaglefan
Feb 09, 2010 09:29 |  #4
montanawild wrote in post #9573559 (external link)
I'll probably just see if they provide the service and what it costs for down the road. At which point "could" it start affecting image quality?
krb
Feb 09, 2010 09:31 |  #5
eaglefan wrote in post #9573578 (external link)
Well, if it gets so thick that it begins to completely block off the light coming through then it could...
I've never heard of it actually causing an issue.
-- Ken
Gear list
Phil ­ H
Feb 09, 2010 09:39 |  #6
I've solved the dust problem with my 17-55 by no longer looking into the lens. Good advice from krb - lay your camera on its side.
EOS 7D l EF-S 10-22 l EF-S 15-85 l EF-S 17-55 l EF-S 60 Macro l EF 70-200 f/2.8L IS l EF 85 f/1.8 l 430EX x2
dovaka
Joined Sep 2009
Feb 09, 2010 09:56 |  #7
i always lay mine down on its side as well just because it seems more stable that way
i own way to much crap to list it all here and try to keep it up to date
lazyshooter
Joined Sep 2009
Feb 09, 2010 10:17 |  #8
krb wrote in post #9573556 (external link)
Why can't I think of things like this...:oops: Natural looking too.
I leave my 24-70L hood on just for thread/glass protection also.
5D Mk II, 30D, EF24-70mm 2.8L, EF70-200mm 4L, Tamron 17-35mm, EF50mm 1.4, EF85mm 1.8, lots of manual lens via adaptor.
tkbslc
Feb 09, 2010 10:19 |  #9
Maybe I will invent a line of hoods with a mini-kickstand.
Taylor
EOS Rp | iPhone 11 Pro Max
hobbes2112
Feb 09, 2010 10:25 |  #10
Dust inside a lens has to be really bad before it affects the image. You'll get a tiny amount of very localized softness but it has to be crazy bad before you'll see it.
A similar topic... http://www.lensrentals​.com …0/front-element-scratches (external link)
sparkin
Feb 09, 2010 10:29 |  #11
Phil H wrote in post #9573644 (external link)
Excellent advice! :) This is how I fix all my dust-in-lens problems too.
71sbeetle
Gallery: 31 photos
Feb 09, 2010 10:37 as a reply to  @ sparkin's post |  #12
I cleaned 3 or 4 17-55mm lenses for friends, had I known how to do it before I sold mine I would have probably cleaned it to, it is so easy to do !
As for it making a difference before and after cleaning .... not one bit !!!
gareymartin.com (external link)
gear list | CPS.
Feedback:
eBay (external link) | POTN
VWVortex (external link)
snyderman
Feb 09, 2010 10:39 |  #13
dovaka wrote in post #9573755 (external link)
Bingo. Me, too. With a longer lens on the camera, (70-200) it almost lays flat when you put the camera on its side.
dave
Canon 5D2 > 35L-85L-135L
KHuizer
Feb 09, 2010 10:53 as a reply to  @ snyderman's post |  #14
When i had the EOS 450D i also put it on its side, this was the most stable and handy.
Now i have a EOS 7D and apparently somebody thought it would be nice to have the thing you 'connect' your strap to (i don't know what it's called in english :oops: ) to stick out so you can't place the camera firmly on its side :confused:
Canon EOS 7D / BG-E7 / Canon 24-105mm f/4 L IS USM / Canon 100mm f/2.8 L IS USM Macro / Canon 10-22mm f3.5-4.5 USM / Sigma 30mm f/1.4 / Canon 50 f/1.8 II / Canon 70-300 IS USM / 430EX II
anthony11
Feb 09, 2010 11:29 |  #15
bannedPermanently
tkbslc wrote in post #9573892 (external link)
I'd like to see something like a block of semi-rigid foam with an elastic loop on one end to go around the lens barrel. One could position it somewhere along the length where it wouldn't touch anything that moves.
Mind you, it'd look dorky as hell.
5D2, 24-105L, 85mm f/1.8, MP960, HG21, crumbling G6+R72, Brownian toddler
6,686 views & 0 likes for this thread, 24 members have posted to it.
670 guests, 119 members online
