Thread started 09 Feb 2010 (Tuesday) 15:11
Cropping for development?
360°
Feb 09, 2010 15:11 |  #1
what is the best way to crop a photo if you want to develop it?
usually i crop a photo and when i develop it, there are edges missing
List Of Gear:Canon 5D Mark III---1D Mark III---Canon 5D Mark II---Canon 85 F1.2--Canon 100mm f2.8 macro---Canon 24-70 F2.8--- Canon 70-200 F2.8 IS II---Canon 300mm F2.8---Bunch of pocketwizards
tkbslc
Feb 09, 2010 15:14 |  #2
Does develop = print?
You are probably not taking into consideration the aspect ratio of the paper. 2x3 does not scale perfectly to 5x7,8x10, 11x14, 16x20, and most other common sizes.
Taylor
EOS Rp | iPhone 11 Pro Max
360°
Feb 09, 2010 15:56 |  #3
tkbslc wrote in post #9575993 (external link)
yes print
and for example 4x6 print... is there some kind template for cropping for the standard size photos
tzalman
Fatal attraction.
Feb 09, 2010 16:01 |  #4
The crop tool in any photo editor will have preset crop box ratios that correspond to standard paper sizes plus the ability to set a custom ratio.
Elie / אלי
SkipD
Joined Dec 2002
Feb 10, 2010 04:28 |  #5
There are other factors involved in printing. Our inkjet printer, for example, cannot print to the edge of the paper on one end. There's a 1/2-inch white border left in any print made by it because of how the paper is handled.
Skip Douglas
tzalman
Fatal attraction.
Feb 10, 2010 06:25 |  #6
SkipD wrote in post #9580004 (external link)
Right, that's where the custom crop setting comes in. For instance, I usually print with a 1 cm. border. Having an equal border all around the print changes the ratio aspect of the printed area, so I use "Custom" rather than a preset.
Elie / אלי
neilwood32
Feb 10, 2010 06:50 |  #7
tzalman wrote in post #9580353 (external link)
IIRC all of the main packages (PS CSx, PSP, Gimp, etc) allow either presets as per the first image or custom by entering sizes in the boxes (circled in red)
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
asysin2leads
I'm kissing arse
Feb 10, 2010 09:07 as a reply to  @ neilwood32's post |  #8
I always crop my images via CS4 before I send them to print. If I send an uncropped image to the lab, them I'm relying on someone else to determine what I want in a given dimension. If I eliminate the need for someone else doing it, then I ensure that the image is printed correctly. Most of your pro labs (Mpix, Millers, WHCC, Bay Lab and the other dozens) usually have a better handle on this as opposed to the local pharmacy, who has no clue about cropping or proper color management.
Kevin
https://www.google.com ….com&ctz=Americ​a/New_York (external link)
tkbslc
Feb 10, 2010 12:09 |  #9
360° wrote in post #9576254 (external link)
yes print
Yes, any photo editor can do that. If you don't have one, I would recommend getting one of two free programs which can help you - Picasa and Photoscape.
Taylor
943 views & 0 likes for this thread, 6 members have posted to it.
2679 guests, 163 members online
