So when you goes send / take your digitals to be printed by a lab, which format do you use ... TIFF JPG EPS, etc.
d'homme Member 165 posts Joined May 2005 More info | Jun 29, 2005 10:39 | #1 So when you goes send / take your digitals to be printed by a lab, which format do you use ... TIFF JPG EPS, etc.
cmosdos Member 50 posts Joined May 2005 Location: Hickory, NC More info | Jun 29, 2005 12:08 | #2 TIFF if I can.
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Jun 29, 2005 12:15 | #3 tiff, unless it's an emergency, and I need prints, NOW! Then I take jpegs down to grocery store.
neil_r Cream of the Proverbial Crop Landscape and Cityscape Photographer 2006 18,065 posts Likes: 10 Joined Jan 2003 Location: The middle of the UK More info | Always full size TIFF Neil - © NHR Photography
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | Jun 29, 2005 12:58 | #5 Depends on the lab. Winkflash will even take TIFF16.
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | BrandonSi wrote: Level 10 jpg from final TIFF's. Why level 10, and not 12?
BrandonSi Nevermind.. I'm silly. More info | jfrancho wrote: Why level 10, and not 12? Beacause WHCC said so.
Jun 29, 2005 15:33 | #9 Thanks for your input. I'm getting reading to print the shots I took from the wedding over the weekend. I guess I should burn to a CD and send out to be printed. My dialup won't handle that many tiff files (maybe 75).
AjP Senior Member 813 posts Likes: 1 Joined Jun 2005 Location: DFW, US More info | I print @ winkflash and always TIFF "Photography takes an instant out of time, altering life by holding it still."
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | BrandonSi wrote: Beacause WHCC said so. ![]() http://whcc.com/faqs.html#10 Why a level 10 JPEG, don’t you lose quality in the large prints? JPEG compression is a very efficient, lossy image compression algorithm designed specifically for saving photographic images. It takes advantage of how humans see color versus brightness to only save information needed to reproduce the image for people to view. Image data is lost during compression, but at high levels of quality you will not see a difference between a Level 10 JPEG and a TIFF printed to photographic paper. JPEG compression is perfect for transient files for sending to the lab for printing, but avoid using the compression as a working file type. Also avoid opening a JPEG, making changes, and resaving it again as a JPEG repeatedly. If your workflow calls for this to happen, save your files as TIFF or PSD files until they are complete and ready for output, at which time you should save them as a level 10 JPEG. Any JPEG artifacts you see in your prints come from the JPEG file coming out of your camera, not from saving them as a level 10 for output purposes. I understand jpeg compression and that while I may not see a difference, the data suggests there is. I am usually getting larger prints, at least 8x12". Also, how can I take advantage of 12 bit color, if I convert my raw files to jpeg? Am I diluded in thinking that the lab cannot print those colors? Are they converting them to 8 bit? I'm not trying to sound fecetious here, just questioning the logic of a workflow centered around providing the best quality end product. I have no doubt that high quality jpegs can produce great prints, I have thousands from my s500 and pre-optimized workflow with the slr (300d).
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jun 29, 2005 16:41 | #12 Read the FAQ at this site Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Jun 29, 2005 17:15 | #13 I think the best advice is to follow the lab's advice. mpix.com takes tiffs and recommends sRGB color space. shutterfly takes jpegs in sRGB, same for EZPrint (smugmug) and my local grocery store.
Jun 30, 2005 08:56 | #14 |
| Latest registered member is Frankie Frankenberry 1277 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
