Thread started 10 Feb 2010 (Wednesday) 17:24
Live View sensor damage?
craigsharp
Feb 10, 2010 17:24 |  #1
I've done a quick search on the subject, but found nothing to consistent... Approximately how long can I keep Live View on without damaging my sensor? BTW I have a XS... I plan on shooting Balet and T-Ball pictures for my daughter and it'll be hard enough to view through viewfinder, so i was planning on just using live view??? any ideas???
Craig Sharp
canon digital rebel xs w/ grip
50mm f1.8, 18-55mm kit, 24-85mm 3.5/4.5 USM
Manfrotto 3011N Tripod Legs
Manfrotto 056 Junior 3-D Head
blackhawk
Feb 10, 2010 17:25 |  #2
Don't point it at the sun...
You got to know when to hold 'em, know when to fold 'em
Know when to walk away and know when to run
You never count your money when you're sittin' at the table
There'll be time enough for countin' when the dealing's done
artyman
Sleepless in Hampshire
Gallery: 17 photos
Feb 10, 2010 17:25 |  #3
Live view on my 7D flips the mirror back down after a minute without any action, as the camera goes into standby mode. How long have you got yours set before it goes into stadby.
Ken
davebmck
Feb 10, 2010 17:27 |  #4
No real limit unless you're pointing at a very strong light source, like the sun. You have a bulb setting on your camera and you can use that in live view, so obviously thats not a problem.
Canon 5D Mark II, 1D Mark IV
Canon 17-40mm f/4L, Canon 100-400mm f/4.5-5.6L IS,
Canon 100mm F2.8 USM Macro, Canon 50mm F1.8
Canon 24-105mm f/4L IS, Canon 500mm f/4L IS, Gitzo 3530LS Tripod, RRS BH-55 Ball Head
Canon 580EX II and 430EX Flash, Canon MR-14 EX Ring Flash
GSeries1
Feb 10, 2010 17:30 |  #5
I'm guessing it depends on the magnification of the lens... I imagine a 1200mm lens pointed at the sun could cook a sensor fairly quick...
Canon 1D | Canon G9
blackhawk
Feb 10, 2010 17:44 |  #6
Bright lights (point source), fire, molten steel and such might cause a sensor melt down.
Be wary of far red bandwidths which are nearly invisible to the eye, but still there.
Brett
Feb 10, 2010 17:45 |  #7
craigsharp wrote in post #9584064 (external link)
Learn to use the viewfinder. Unless they freeze and wait for live view to attain focus, you're going to get a lot of OOF shots.
The LV on your XS isn't meant to be used like the back of a P&S camera's LCD.
craigsharp
Feb 10, 2010 17:54 as a reply to  @ Brett's post |  #8
Thanks for all the quick replies... I don't plan on having it on for too long... just to frame shots... then use viewfinder...
Craig Sharp
RDKirk
Adorama says I'm "packed."
Joined May 2004
Feb 10, 2010 18:13 |  #9
Long use of the sensor does warm it up. The camera has an automatic system that will warn you when it gets too warm, then shut the system down. But I use Live View constantly-- I've had my 5D2 Live View on for more than half an hour without that happening. I suspect it needs to be out in bright sunlight or in an extremely hot climate to give it a heat boost before it can actually get that warm. Whether it materially increases noise to run Live View for long is for pixel peepers to worry about. I haven't noticed a difference.
However, as has been mentioned, Live View isn't really designed to be used in any kind of action mode. You would be better off using the viewfinder for such.
Brett
Feb 10, 2010 21:24 |  #10
craigsharp wrote in post #9584308 (external link)
I don't mean to sound like I'm an expert at this, but that's impractical. You're suggesting activating LV, framing the shot holding the camera in front of you, keeping it there while you bring your eye to the viewfinder, de-activating LV and then taking the shot?
Unless it's from a tripod, but I still don't think that's a practical use of LV. I used to own an XSi, and LV has limited uses: landscape/arch and macro from a tripod.
GSeries1
Feb 10, 2010 22:45 |  #11
Brett wrote in post #9585647 (external link)
Yeah,,, LV only seems useful for Landscapes and maybe some studio stuff to me.
Canon 1D | Canon G9
10megapixel
"I'm a little slow"
Location: Â…Â…Surrounded by Corn and Rednecks in Indiana
Feb 10, 2010 22:48 |  #12
Brett wrote in post #9584214 (external link)
That's what I was thinking.
Gear List & Feedback
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Feb 10, 2010 22:52 |  #13
GSeries1 wrote in post #9586198 (external link)
I'd have to agree. I think you'll find that attempting to use LV for any sort of action shooting is going result in missing more shots than you get. IF you were to prefocus on a single spot, from a tripod, and then activate the shutter with a remote when you see the subject action you wanted might work moderately well; but otherwise, stick to the viewfinder.
RDKirk
Joined May 2004
Feb 11, 2010 06:30 |  #14
I use it constantly for portraits, but I also use a tripod or camera stand constantly for portraits.
craigsharp
Feb 11, 2010 07:11 as a reply to  @ RDKirk's post |  #15
Ya... I see y'alls points... I guess what I was think I could use LV for was for group shots for team pictures... I realize now that any slight movement of the kids would bring the shot OOF for single portraits... Again, Thanks Very Much!
Craig Sharp
4,731 views & 0 likes for this thread, 11 members have posted to it.
1622 guests, 141 members online
