Thread started 10 Feb 2010 (Wednesday) 18:21
Alienbee Honeycomb Grid
Sublimejoe
Feb 10, 2010 18:21 |  #1
I searched around a bit (here and elsewhere on the internet) to find some info on the Alienbee Honeycomb grid. I have been using Alienbees lights for a few years now and have always just used them with umbrellas. I have seen a lot of people using them with the grid and I wanted to know exactly what the benefit is of using them. Any help would be greatly appreciated!!
Cliff Notes:
Can someone explain the use of the Honeycomb Grid to me, please and thank you!
http://www.ShootJoeC.c​om (external link)
http://blog.shootjoec.​com (external link)
Tyger
Feb 10, 2010 20:22 |  #2
Basically a honeycomb grid is a way of controlling the circle of the light, the more shielded the light the smaller the circle. they come in various degrees so a 10deg grid will have a smaller circular projection of light. These typically are used for background lights or hairlights but not limited to them. Also be aware to turn off the modeling light when using the grids since they can cause your strobe to overheat. here's a good visual honeycomb grid (external link) (just scroll down a bit)
You create your reality.
jeromego
Feb 10, 2010 20:29 |  #3
Tyger wrote in post #9585232 (external link)
Interesting! Never had overheating problems with the grid on.
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
Tyger
Feb 10, 2010 20:41 |  #4
jeromego wrote in post #9585286 (external link)
you probably wouldn't, but possible especially after extensive constant use. I always believe in being cautious and avoiding possible scenerios. highly unlikely though with my low powered ab400's :)
bobbyz
Feb 10, 2010 21:11 |  #5
I had noticed it. Went to take off the grid and almost got burnt. Now I keep my modeling lights off when using grid.
Fuji XT-1, 18-55mm
ZSutton
Feb 11, 2010 08:57 |  #6
I've had problems too. On my AB400 no less. After shooting with a model for about 20 minutes, I started smelling burning. I found out it was my AB400, I took off the grid and shot without it and had no other problems.
-Sutton
Gear List | Website (external link) | Instagram (external link)
Big ­ Mike
Feb 11, 2010 10:33 |  #7
Grids are used to control the spread of light.
For example, you might want to put a bright spot on the background and have it fall off to create a gradient...rather than lighting up the whole background.
Or maybe you are using a hair light and you don't want any of that light getting back directly on the camera, causing flare.
Instructor at The Canadian Photography Learning Centre (external link).
Blog (external link)
5,370 views & 0 likes for this thread, 6 members have posted to it.
1505 guests, 131 members online
