Thread started 11 Feb 2010 (Thursday) 11:32
Stitched vs wide angle geometry
tkbslc
Feb 11, 2010 11:32 |  #1
Help me with some photo theory here
Say you stich 3 portrait oriented shots together from a 20mm lens and it works out to be the same FOV as a 10mm lens shot landscape (just an example, not saying that would really equate). Is the geometry and perspective of the shot the same in the sticthed shots vs the wider angle lens? It seems like it should be because you are the same distance away from the subject, but then with the actual camera movement, perhaps it changes some things?
Just wondering if anyone had any experience with this and could explain how it is the same or different.
Taylor
EOS Rp | iPhone 11 Pro Max
Jon
Joined Jun 2004
Feb 11, 2010 11:41 |  #2
Not really. If you had a 20 mm Tilt-shift lens with enough shifts to accommodate the 10mm FoV, you'd get the same effect. With three photos from a regular 20 mm lens, you'll typically be changing the angle of the camera, hence of the film plane, for each of the three shots. So the geometry at the edges of the composite will be different from the geometry at the edges of the 10 mm UWA shot. Pivoting the camera/lens combo about the nodal point is more like using a "panoramic" camera with a curved film/sensor plane than using one with a flat sensor plane.
Jon
Cocker Spaniels
tkbslc
Feb 11, 2010 11:59 |  #3
That's kind of what I thought. So since I am rotating the camera a bit, the parts of the frame near the edges are not being pulled in at such extreme angles, hence less crazy distortion - for better or worse.
Taylor
Jon
Joined Jun 2004
Feb 11, 2010 15:35 |  #4
Bingo!
Jon
Cocker Spaniels
721 views & 0 likes for this thread, 2 members have posted to it.
2679 guests, 163 members online
