I have read in many places that when using a Tripod that you should turn off your Image Stabilizer. I fully understand this and the need for it. But my question is - Do you also need to turn off the Image Stabilizer if your using a monopod. The reason I question this is because when I use my monopod - I have total control of the movement of up and down - the monopod stabilizing this action - but I can not control the movement from side to side - thus - should you keep the Image stabilizer on when using a monopod??
