Thread started 12 Feb 2010 (Friday) 17:01
YN-460 stuck at 1/1 power?
unchman14
Feb 12, 2010 17:01 |  #1
So I just got in a couple of YN-460's earlier in the week. Took them out of the box, tested all of the modes and power levels, and they both worked fine. Then today I was shooting some water drops and triggered both flashes off camera about 30 times. I let the flashes cool down, then I grabbed one (the now broken one) and put it on my camera to do some more shooting.
I hit the power button and it popped once before even turning on. I figured it was just releasing the stored power or whatever. Then I shot at the lowest power setting and it was taking abnormally long to charge back up. I tested it at a few different power settings and modes, and they are all putting out 1/1 power.
I'm curious to see if anybody else has had this problem and if there is a fix for it or if I should just contact yongnuo and try to get a new one.
-Cody
Canon 1D Mark II | 70-200 f/4 L | Rokinon 14 f/2.8
Cody Unczur Photography (external link)
SwitchBlade
Feb 13, 2010 01:43 |  #2
One assumes you've done the usual of pull the batteries for half hour then slap in fresh ones?
5D | 40D | Σ24 f1.8 | 50 f1.8 II | 85 f1.8 | 70-200 F4L | 540EZ x2 | Nissin Di622
unchman14
Feb 13, 2010 07:16 |  #3
i've changed the batteries, but haven't waited a half hour. I'll try that.
watt100
Feb 13, 2010 09:06 |  #4
unchman14 wrote in post #9598014 (external link)
-Cody
so you're saying the lights show a power level, for example "5" and when you measure it with a light meter it indicates the maximum full power "7" ?
unchman14
Feb 13, 2010 12:45 |  #5
Did what you suggested SwitchBlade, no change.
watt100 wrote in post #9601628 (external link)
Pretty much. Even with the back panel showing any power setting, the flash will still put out the full amount of light (1/800s). I tested it by taking test shots with my working flash at all the different settings, keeping my camera settings the same, then used the "stuck" flash, and it was putting out the same light as the working flash at full (1/1) power.
unchman14
Feb 17, 2010 06:12 |  #6
anybody?
1,957 views & 0 likes for this thread, 3 members have posted to it.
1113 guests, 172 members online
