Thread started 12 Feb 2010 (Friday) 23:24
Please help me figure this out...
juxtagirl
Feb 12, 2010 23:24 |  #1
I have a nifty fifty that I am unable to effectively use on my 5Dm2. I can take one photo with it then the viewfinder goes black. I am able to switch to live view and manual focus, but after the first pic that in the only way I can shoot.
What do you think is up?
Canon EOS 5D Mark II Gripped :: Canon EOS 30D :: 24-105mm f/4L IS USM :: 50mm f/1.8 :: 100mm f/2.8L Macro IS :: 3 B800's :: ABR800 w/ moon unit :: AB 42" PLM v1:: AB 86" white PLM v2 :: AB 64" silver PLM v2 :: 32x40 AB Softbox :: AB White Beauty Dish :: Metz 48AF-1 :: and a pretty Cheeky Lime bag :)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Feb 12, 2010 23:27 |  #2
Sounds like its causing a mirror lockup of some sort
juxtagirl
Feb 13, 2010 00:06 |  #3
That is what I thought too, but why and how do I avoid it? I have two other great lenses that have no issues, but I really wanted to play with this lens and see how it did on FF. I am very concerned that if it happens with this lens it will happen with others later.
siriusdogstar
Feb 13, 2010 00:15 |  #4
Please tell us which nifty fifty? -- some, such as adapted M42 Asahi Takumar, the 5D mirror hits when lens is focused at infinity, but not when focused closer.
juxtagirl
Feb 13, 2010 00:16 as a reply to  @ siriusdogstar's post |  #5
Canon 50mm f/1.8 II
siriusdogstar
Feb 13, 2010 00:35 |  #6
Is camera battery almost discharged? If not the lens has a problem...could be as simple as dirty electrical contacts. try cleaning contacts with q-tip dipped in alcohol; they should be shiny like polished brass.
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Feb 13, 2010 01:23 |  #7
can't imagine a Canon Nifty causing mirror interference unless it's been damaged (check rear of lens to see if there's any scuff marks maybe?)
Does the problem happen if you're shooting in Av mode and have selected f/1.8? just wondering if it could be sticking aperture blades...
TF posting: here :-)
juxtagirl
Feb 13, 2010 02:00 as a reply to  @ joeseph's post |  #8
The lens is in great condition. It originally lived either on my xti or when not on that body, it was tucked away in a padded case. I inspected it and there is no damage to it. The contacts are bright and shine. It has never been dropped or even bumped. It was purchased new. It still works without issues on the xti.
I shoot in manual. I tried it with several different f stops. Each time the same thing happened. First shot works then after that the viewfinder is black.
So strange....
The ­ Moose
Feb 13, 2010 02:09 |  #9
Very odd situation. Have you tried taking the battery out of the 5D, as well as the backup battery? Or reset to factory settings? I can't think of what would fix it because it's never happened to me but most people seem to suggest that for problems like this. Hope it gets sorted.
siriusdogstar
Feb 13, 2010 02:39 |  #10
hmmm, well if the mirror is hitting back of lens, which gives the same symptoms...sorry, mine is not handy -- does the rear of the lens move into the lens body when the lens is focused close? I can't remember -- anyway if the rear portion of the lens does move into the body when lens is close focused, the mirror should not hit it, if mirror hit is the problem. Try it again with lens manually focused for close up. If the problem persists, then mirror hitting is not the cause. I'd next call canon support...
1,820 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is RawBytes
1537 guests, 164 members online
