Thread started 13 Feb 2010 (Saturday) 10:32
eagle photo help
riggerjoe
Feb 13, 2010 10:32 |  #1
Okay so i have been chasing eagles around Kansas for sometime now. The birds are making a comeback to the area but they are still rare enough that it's still exciting to see them and I get eagle fever.
Driving down the highway yesterday i spotted this bird, just when you are not chasing them there they are right?
I want to edit the pic but I am not the best with PS and was loking for suggestions and comments. I want to learn so if you have creative input I am all eyes and ears.
Thank you
7D, XTI both gripped, an array of glass and a positive attitude! www.greenboxphotograph​y.com (external link)
Rich_A
Feb 13, 2010 11:02 |  #2
Joe, to be honest, there's a lot working against you in the photo. You've shot almost directly into the sun with the eagle silhouetted against the mid-toned sky. By upping the exposure on the entire image, you're probably going to blow out the sky. You are probably not going to recover a heck of a lot of detail in the eagle since it is so under-exposed. You could attempt to use an adjustment curve in PS, but they're pretty finicky, especially when dealing with 8-bit JPG images. If you've shot this in RAW, there's hope in using Canon Digital Photo Pro and upping the Shadow slider, which could recover a bit of eagle detail without blowing out the sky, but again this is of limited utility.
My best advice is going to sound trite and snarky, but in all honesty, I would record this as a learning experience and make an effort to shoot test shots while in the field to judge exposure. I would typically meter on a mid-toned object in the same generally vicinity to find out the correct exposure for a backlit subject and then manually expose or use Exposure Compensation to "overexpose" the background or at least to avoid it fooling the meter like in your shot here.
If this sounds a bit complication, I would highly recommend Brian Peterson's Understanding Exposure (external link). To get a handle on tricky lighting down the road. It helped me immensely when I was starting out with wildlife photography.
Backlighting is one of the most challenging conditions and you have to figure out what you're willing to lose: either let the sky blow out by using +1 or even +2 EV, or lose the details in the subject and allow it to fall into shadow or even a silhouette. Either of these choices can work for the final product, but it's an either or unless you're shooting RAW (and even then might not be completely possible to recover both).
I hope this helps.
Rich
Jack ­ Cooper
Feb 13, 2010 11:11 |  #3
It is always hard when you get a great pose like this one under such unforgiving conditions. Eagles often return to the same tree, in my experience. Maybe next time.
riggerjoe
Feb 13, 2010 15:58 |  #4
Thanks for the input guys. the pic was snapped off the side a major highway and space and time where limited to get things set up. I wish that the bird would go back to the same tree but since there is no habitat for him around this area i would guess he was just passing through on his way to some place better, as if he was local then i would find the area land owners and go from there.
I was in high hopes that someone could point me in direction and perhaps the link that Rich posted is the place for me.
thanks to both of you for your time and info.
Joe
1,324 views & 0 likes for this thread, 3 members have posted to it.
eagle photo help
998 guests, 107 members online
